Whrilpool GR450LXHB2- The stovetop works, but the oven does not. Both the broil and bake elements do not turn on. The display board and convection fan do work. I tried unplugging it ,turning off the circuit breaker .
It won't bake or broilIf
neither the bake nor the broiler heating elements heat, but the range
burners still work, the clock may be set for a timed or self-cleaning
cycle. Check to be sure the clock buttons and knobs are set properly.
If your clock has a knob that says "push for man(ual)", push the knob
in and try the baking and broiling elements again. If it still does not
operate properly, you probably have a defect in the thermostat,
selector switch, or common wiring.
If the oven does not have a
separate bake/broil/etc. selector switch, the problem may be with the
thermostat. But it's not easy to check the selector switch or
thermostat for proper operation. If you suspect a problem in this area,
call a qualified appliance repair technician.
It won't broil
Usually,
when an oven won't broil, it's because the broiler element is burned
out. The broiler element in an electric oven is the black, pencil-thick
tube at the top of the oven. When the broiler is on, the element glows
red. This element has an expected life-span of several years. It may
last for only one; it may last for many more. When the element burns
out, you need to replace it.
You may get fooled into thinking it's
working, because the oven is hot inside. But many electric ovens use
the broil element, too, during the preheat and bake cycles. So the food
may be getting heated only by the broil element, which causes poor
baking results.
If the bake element is burned out, replacing
it should solve the problem. Otherwise, you need to further
troubleshoot the oven's electrical system to locate the defective wire
or component.
If the thermostat bulb is not dislodged, it's likely that the thermostat or sensor is either mis-calibrated or defective.
Electronic
ovens with a digital display use a sensor to monitor oven temperature.
To solve temperature problems for these models, you may need to replace
the sensor. On some digital-display models, you can calibrate the
temperature using the key pad. See your operator's manual for details.
Ovens
without a digital display often use a mechanical system for controlling
temperature. On many of these units, you can remove the thermostat knob
and adjust the knob itself to more accurately represent the actual
setting of the thermostat.
If, when you remove the knob,
there's a screw on the back of it with a small calibration plate, you
can loosen the screw, adjust the plate, then tighten the screw again.
If the knob isn't adjustable, and the oven temperature is off by more
than 30 to 40 degrees, you need to replace the thermostat to solve the
problem.
Hello kimberlymaso - If you are referring to the bake element, but the broil element works then you would need to just replace the bake element. If both your bake and broil element does not work, then there might be a problem with the wiring communication. However, if the oven does not bake and/or broil but the cook top works; contact a professional to diagnose the EOC (electronic oven control).
If you are referring to the bake element, but the broil element works then you would need to just replace the bake element. If both your bake and broil element does not work, then there might be a problem with the wiring communication. However, if the oven does not bake and/or broil but the cook top works, contact a professional to have the EOC (electronic oven control) diagnosed.
