Hi pavrj2003,
Have you put the switch into internal setting and tried? And, have you set the SAP off and switched the audio to stereo?
If you are sure the settings are correct and still no audio it may be a
defective audio system internally. If so, it will require a tech to test it out. If the audio control system is not functioning properly
(no mute and no volume indications) you may need an IC replacement.
This could cost a fair amount; $150 or higher (plus the house call).
It is possible the audio went defective during the move. Sometimes a
few whacks with the fist over a few places on the cabinet will wake up
a bad connection or errant solder joint that was deactivated during
transit.
Also, try the speaker switch again on the back panel; switch it a few
times to burn through any corrosion that might have built up over the
years.
best regards,
Jazerblue
