Akai Mpc2500 Music Production Center Logo
Posted on Aug 24, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
About to record sounds and sequences to pro tools - all of a sudden the sounds do not play except for in trim mode - what happened???
  • krishb1 Aug 25, 2009
    there's a window called "trim" where you edit the samples/sounds. in that window and also the "directory" window the MPC actually generates sound. The click can also be heard. but when the MPC is in regular "Main Screen" playing mode there is no sound and the pads have no sound when you hit them
  • Anonymous May 11, 2010
    What do you mean trim mode?
Anonymous
Level 2:
  • Expert 62 Answers
  • Posted on Sep 13, 2009
Anonymous
Expert
Level 2:
Answers
62
Questions
Helped
23692
Points
118
Read the manual. I think you'll find that you've recorded them as sound bytes instead of full recordings. If that don't work get in touch with Akai.com. You paid good money for the machine and YOU ARE THE CUSTOMER.
Good Luck
I have a behringer 2442 usb and i cannot record my voice with pro tools? i, using windows xp everything works except record it wont pick up my voice threw the mic? i went to behringer.com for the drivers...
If it's a problem with the drivers, when you go to the manufacturer's website to download them, merely type in the exact product you have and the website should give you the specific driver/s for your product. If you go to the icon for XP's volume and recording tools, make sure that you've engaged the mic to function and that it functions at a sufficient level. You can find those tools under Control Panel, and then select SOUND, and then select RECORDING to adjust the mic functions.
While using korg m50 editor using usb data cable there is no sound from my lap.the sound is only from my head phone connected to my keyboard directly?
Are you connecting to the laptop and using it as a midi controller? You can record midi notes from the keyboard and send them to your laptop via USB using any midi sequencer program (reason, logic, etc). Create a midi track, select the input of that track as your keyboard, then hit record to play some midi notes. To hear what you record, you have to set the output of the midi track to whatever midi sounds or instrunents you have installed on your laptop.
If you are trying to record the actual audio sound the keyboard makes, use an audio program such as cubase, sonar, audacity, pro-tools, and either mic the keyboard, or connect one of the other audio outputs (1/4" TRS) to an audio input on your DAW, and record an audio track that way (as opposed to a midi track).
I am trying to record sounds from my keyboard into my MPC 1000. I have what I think is the proper set-up. MIDI sync...softthru as track...etc. Problem is when I set it up I can play one sound and record...
It is not clear whether you are recording audio or MIDI. If you recorded Audio samples, you will get the same sounds back even if you change the voice on the keyboard.
If you record a MIDI sequence, and then play it back you will STILL get the same sounds UNLESS you also record the MIDI voice or patch changes so the voice is changed as it occured when you recorded it. Usually there are options taht you can enable or disable voice changes.
Feb 11, 2011 • Akai Music
2answers
I hooked up my Mackie MR5 Monitors to my MacBook Pro through an audio interface, I use it to record my band in the studio I use out of my basement. Except everytime I try to use the monitors they give me...
try hooking headphones to the output and see if the crackling is still there.
then, try it with the speakers, at a lower computer voume level and higher speaker volume level. perhaps the headphone output is too loud and distorting in the speaker inputs.
How do I play the O1WFD sequencer through the Triton Pro X??
Here is a link to a site with all the info you need:http://forum.recordingreview.com/f18/midi-troubleshooting-101-a-5208/ You will need to join which is free and well worth the time. I also recommend downloading the free book Killer Home Recording Setting UP.
May 16, 2010 • Music
1helpful
I own a korg triton music workstation sampler and when I create a sequence using the 16 tracks and I want to make a song using a que list all of my inserted effects on all the instruments do not work when...
you need to ensure that you have recorded the midi command to select each effect and level of that effect. this can be done in the midifile. you need to start record and very quickly at the start of the song you need to select the effect and set the level, whilst in record. this should write the setting into the song. you can check this if you use an external sequencer.
Dec 13, 2009 • Music
1helpful
Recorded midi, output set to dtxpress channel 10 no sounds is gen
You have to discover the receive channel for the dtxpress. Try downloading Midiox which is a freeware app that actively displays everything that is happening midiwise in real time.
1helpful
Can't get Casio CTK 601 / 611 to function as MIDI Contrller
I'm not at home right now where all my manuals are so I'll try to explain with out. You will have to set it so that the keyboard is the slave device. Try setting it to Omni receive. It has to be able to listen for all midi channels at once. You have to write a sequence on your computer and hook it to your keyboard by using midi out on the computer to midi in on the keyboard in order for you to use the computer as a controller. If you need the keyboard to create the sequences then you have to hook the midi send on the keyboard to the midi in on the computer play/enter your notes into individual tracks in your software then assign channels, voices etc to each track and save the sequence. Then when you hook it up the other way the sequence will play just like an audio recording except the sound w2on't be there. What you have recorded by creating a sequence is a series of midi messages that the keyboard will receive if you have it set properly and hooked up ptroperly which it will translate into sound. This is a minimalist explanation at best. You will have to have a better understanding of not only your keyboard but also your software and midi in general. There are some pretty amazing things you can do with midi. For instance if you have a lighting controller that is midi capable you can i,mbed all the lighting scene changes for your song in order on one track. You can also control your guitar effects pedal to change effects automatically while your playing. Once you get a handle on it you are only limited by your imagination and your budget. Hope this helps in some way.
Jun 01, 2009 • Music
Yamaha 88 key piano grand plays wrong pitches w/ changing volume
If it has a sequencer/ recorder built in, you have the ability to change the pitch/ detune by using some key strokes after initiating the program mode. If your not sure how to do that, try unplugging the keyboard for thirty seconds and push the power button while it's unplugged, then plug it back in. Any better? What model is it.
Top Akai Music Experts
ilias
ilias
Phelix Oguta
Phelix Oguta
Are you an Akai Music Expert? Answer questions, earn points and help others
