Toshiba DKT3020SD Corded Phone Logo
Posted on Aug 24, 2009
Can't change previous name
I just moved into this office, and I can't figure out how to get into the edit mode to change the name. The previous entry said "DN + #621" but what is "DN"?!
Please help - I'm getting really frustrated!
Anonymous
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Mar 26, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
7731
Points
9
DN is your extension number.
How to change time and date
Follow this procedure to set the current date and time.
1. Open all three one-touch speed dialing panels.
2. Press [Data Registration]
3. Press [up arrow] or [down arrow] until <TIMER SETTINGS> appears, then press [Set]
4. Press [up arrow] or [down arrow] until <1.DATE/TIME SETTING> appears, then press [Set]
5. Register the current date and time using the numeric keys. Use 24-hour notation to enter the time (eg. 1:00pm as 13:00)
You can also press [>] or [<] to move the cursor without changing a number entry. To restore the previous entry, press (c) (clear)
6. Press [Set]
the message<DATA ENTRY OK> appears on the screen for a few seconds.
7. Press [STOP] to return to the Standby Mode.
We need to change our code
Hi, here is a link to the instructions to change your code. http://www.aaaindustrialsupply.com/articles%5Clockey%5Cm210%5CHow%20to%20change%20the%20code.pdf
We have an MLX-20L and I am trying to change entries as people have moved into different offices. It won't let me edit the entries.
You are just trying to change names?
  1. Press Menu.
  2. Press System Program.
  3. Press Exit or Start.
  4. Press More or Right Arrow Key.
  5. Press Labeling.
  6. Press Directory.
  7. Press Extension.
  8. Dial the extension number that you want to administer.
  9. Press Enter.
  10. Press Drop.
  11. Enter the label information for the extension number selected. (Remove the plastic covers from the line and feature buttons, and remove the white labels. You will see the letters “A-F” on the display and the letters “G-Z” on the buttons. Enter the new name of the extension. See note below.)
  12. Press Enter.
  13. Press Exit or Back.
  14. Press Home or Exit to exit programming mode.
1helpful
Forgot how to add new phone numbers and names to my phone
Creating Phonebook Entries To store names and numbers in your Phonebook, please follow these steps: When the phone is in standby mode, press [phonebook icon] (on the left side of the four-way key). To create a new phonebook entry, press the NEW soft key. Edit Name appears. Enter the name for this entry (Edit Name). Use the keypad to enter a name for this entry; the name can contain up to 1 6 characters. (See page 1 1 for instructions on entering text.) If you do not want to enter a name for this entry, your phone will store this entry as No Name. Press the OK soft key when you are finished. Enter the number for this entry (Edit Number 1). Once you have stored a name, EDIT NUMBER1 appears next. Use the number keypad, [right] or [left] on the four-way function key, or the DELETE soft key to enter the phone number 1 ; the phone number can contain up to 32 digits. If you need the phone to pause between digits when it’s dialing (for example, to enter an extension or an access code), press [redial/pause] to insert a two-second pause. You will see a P in the display. You can also use more than one pause together if two seconds is not long enough. Each pause counts as one digit. Press the OK soft key when you are finished. EDIT NUMBER 2 appears next. Use the same procedure when entering the phone number 1 to enter the phone number 2. Press the OK soft key when you are finished. Assign a personal ring tone for this entry (Personal Ring). You can attach a personalized ring tone to each phonebook entry; the phone will use this ring tone when this person calls. Move the cursor to highlight one of the 20 different ring tone options. As you highlight each ring tone, you will hear a sample of that tone. When you hear the ring tone you want to use, press the OK soft key. If you do not want to use a personal ring tone for this phonebook entry, select the NO SELECTION option, and the phone will use your standard ring tone setting. Assign this entry to a Speed Dial number (Speed Dial). Your phone has 1 0 speed dial numbers, 0 to 9. Move the cursor to select the speed dial number you want to assign to this phonebook entry, and press the OK soft key. Select NO SELECTION if you do not want to assign this entry to a speed dial number. Press the OK soft key. You will hear a tone confirming that the new phonebook entry has been stored, and DONE! appears in the display. Note: When the shared memory is full, the oldest Caller ID message is overwritten.
How to remove a MS home and student 2007 product key and reentry?
The directions are at this link: http://www.mydigitallife.info/2007/01/12/how-to-reset-or-change-microsoft-office-2007-product-license-key-or-volume-license-key-vlk/comment-page-11/ A word of caution when modifying the registry. Make sure you make a backup of the registry before you make any changes. Select File, export to backupthe registry.
16helpful
6answers
Programming a Name in Toshiba DKT3020-SD
To edit display name on LCD DKT3020-SD.
Follow this sequence:
Mode
Scroll
Enter passwork - 0000 is default
Hold
Hold (again)
DN ID (This is your phone extension #)
Old name should now be displayed. Hit page button to delete letters, scroll button for space.
Use characters for the the associated number key to enter desired name. For example if you want an "F" you would hit the 3 button 3 times. After your name is entered, press hold. Pick up and put down receiver.
Does anyone have clue about the " Pro.Msi" File
An .msi file is a database of all the files, settings, and configuration information for the associated application. When you install Office on your computer, the .msi file is saved in a hidden folder. Without this file, Windows Installer cannot update your configuration, install optional features, or apply software updates. Office cannot be installed, repaired, or updated if the .msi file is not found.
Why is the .msi file missing? The most likely reason for Windows Installer to require the installation CD is because the saved version of the .msi file for Office has been inadvertently or deliberately deleted from your computer. It is also possible that the file is damaged or corrupted.
Occasionally, changing the drive letters associated with partitions on your hard disk can cause this problem to occur — such as changing drive C: to a different letter or moving the hard disk drive from one computer to another. Other possible causes are a damaged or corrupted hard disk or registry file.
What to do when prompted for a missing .msi file If you are prompted for the location of a missing .msi file, you must provide the original installation CD used to install Office on your computer.
  1. Make sure that you have inserted your Office installation CD into the CD drive of your computer. If you installed Office from a network, browse to the network location from which you installed Office.
  2. Click Retry.
In most cases, these steps should resolve the problem and Office can complete the installation and configuration of the needed component.
default.aspx?assetid=za790050011033I don't have the installation CD
Without the installation CD — or for computers purchased from companies such as Dell, HP, Compaq, or Gateway — you need to provide a repair CD to reset the installation created for your computer by the manufacturer. For information on how to apply the repair or installation CDs, you might need to contact the support representatives of your computer supplier.
In many cases, the files that you need are compressed on the repair CD and must be run by using a special program provided by the computer manufacturer. In some cases, the computer manufacturers might have customized the .msi file or changed the file name.
In situations where you cannot obtain the installation CD, your options are the following:
  • Continue with the existing installation of Office without updating. This is not recommended. Your documents and computer might become compromised from security threats.
  • Remove the installation and reinstall Office by using another installation CD. Removing the previous installation may not be possible in severely damaged systems where the registry is corrupt.
  • Run a repair CD provided by the computer manufacturer. For information on how to apply the repair CD, you might have to contact the computer manufacturer or consult the documentation provided with the computer.
If you do not know which version of Office you have installed, the name of the .msi file requested indicates the Office version you have. A table that correlates .msi files to Office versions is provided later in this article.
Office 2003, Office XP, and Office 2000 provide the Detect and Repair command. You can find the Detect and Repair command on the Help menu of almost all Office programs. Using this command corrects identifiable problems such as missing files, corrupt files, registry omissions, or damaged registry entries. It replaces the .msi file if it was deleted, damaged, or is the wrong version. Using the Detect and Repair command usually requires you to provide the installation CD for the version of Office currently installed on your computer.
default.aspx?assetid=za011526611033 How to prevent similar problems in the future To help avoid this problem in the future, use the following guidelines:
  • Do not delete hidden folders or files from any drives on your computer.
  • Do not move drives or change their disk identifier (for example, C: to D:).
  • Install all needed applications as Run from My Computer instead of using Install on Demand (available from custom installation within Setup).
  • Occasionally run the Windows Disk Defragment program to repair cross-linked files, recover lost clusters, and remap bad sectors on your hard disk. Any data present in a bad portion of the hard disk is usually lost and commonly associated with physical damage to the disk. This is most likely the result of high-vibration environments, such as the computer being struck, dropped, or kicked.
If you have Microsoft Windows XP as your operating system, consider using the System Restore option to restore your system to a previous configuration. Consult the Help and Support option of Windows XP for more information on System Restore.
Office 2003 .msi files If you do not know which version of Office you have installed, the name of the .msi file requested indicates the Office version you have. The following tables tell which .msi files go with which Office versions.
File name Description accessed.msi Microsoft Office Access 2003 Developer Extensions mui.msi Microsoft Office 2003 Multilingual User Interface Pack (one for each language) muiwiz.msi Microsoft Office 2003 Multilingual User Interface Pack owc11.msi Microsoft Office 2003 Web Components prjmuicwz.msi Microsoft Office Project 2003 Multilingual User Interface Pack Wizard prjstde.msi Microsoft Office Project Standard 2003 pro11.msi Microsoft Office Professional Edition 2003 projproe.msi Microsoft Office Project Professional 2003 ptk.msi Microsoft Office 2003 Proofing Tools sbe11.msi Microsoft Office Small Business Edition 2003 vismuiwz.msi Microsoft Office Visio 2003 Multilingual User Interface Pack Wizard visprolmxi.msi Microsoft Office Visio Professional 2003 Office XP .msi files File name Description dao.msi Microsoft Data Access Object (DAO) lpk.msi Microsoft Office XP User Interface Pack (one for each language) lpkwiz.msi Microsoft Office XP User Interface Pack Wizard ork.msi Microsoft Office XP Resource Kit pro.msi Microsoft Office XP Professional Edition proplus.msi Microsoft Office XP Professional with FrontPage Edition ptk.msi Microsoft Office XP Proofing Tool Kit pub.msi Microsoft Publisher 2002 sbe.msi Microsoft Office XP Small Business Edition std.msi Microsoft Office XP Standard stdedut.msi Microsoft Office XP Standard for Students and Teachers owc10.msi Microsoft Office XP Web Components Office 2000 .msi files File name Description data1.msi Microsoft Office 2000 Premium Edition (all Office products) data1.msi Microsoft Office 2000 Professional Edition (similar to Premium but does not include Microsoft PhotoDraw) data1.msi Microsoft Office 2000 Small Business Edition (includes Microsoft Word, Microsoft Excel, and Microsoft Outlook) data1.msi Microsoft Office 2000 Standard Edition (includes Microsoft PowerPoint, Word, Excel, and Outlook) data2.msi Microsoft Office 2000 Disc 2 (includes Small Business Tools and Publisher) msowc.msi Microsoft Office 2000 Web Components orkdata.msi Microsoft Office 2000 Resource Kit proofkit.msi Microsoft Office 2000 Proofing Toolkit Note In Office 2000, the file name data1.msi does not clearly identify which version of Office you have. In this case, you need to inventory the installation of Office programs on your computer by examining your Start menu entries or click Add or Remove Programs in Control Panel and scan through the list of entries to determine the version of Office that is installed.
Zulfikat Ali
8helpful
4answers
SKU001.CAB
i want file which name is sku001.cab
Your Toshiba Name Change question of Apr 2008
Maybe I can help, Press ( DN ) + #621
Display changes to USER NAME ?
Enter new name
Press SPKR
1 - moves right
* - moves left
# - toggles between alpha mode / numeric mode
0 - scrolls the alpha / special characters
To blank out any portion of name press 1 ( in alpha mode ) and move cursor to thr right
Good Luck
24helpful
3answers
Change name display on Toshiba DKT2020-SD
I am assuming you want to change the display to read another persons name, or blank. If that is correct:
Press a [DN](labeled intercom on my system) + #621.
That opens edit mode.
an example. My phone reads "MARK 29"
where Mark is the user, 29 the extension. John replaced
Mark, so target is "JOHN 29"
so intercom # 6 2 1 puts me in edit mode
# toggles between alpha/numeric
* moves the cursor, I repeat * until cursor is under M
Hit the 5 key, changes the M to J and moves cursor under the A.
Hit the 6 key, the A changes to M, and the cursor moves to under the R. I hit 0 which changes the M to N. I hit 0 again, the N changes to O.
Hit the 4 key, the R changes to G. Hit 0, G changes to H.
Hit the 6 key, K changes to M. Hit 0, that changes the K to M. Hit 0, M changes to N.
We are done, as the extension number stays the same. Hit spkr key to leave edit mode.
Hope that helps!
# toggles alpha/numeric
Top Toshiba Lands Phones Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Toshiba Lands Phone Expert? Answer questions, earn points and help others
