Texas Instruments TI-84 Plus Calculator Logo
Posted on Aug 24, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I accidentally pressed down for too long on my ti-84 plus calculator and i think it locked itself. how can i turn it back on? I NEED it for school!
A Soveral
Level 3:
President:
  • Master 566 Answers
  • Posted on Aug 24, 2009
A Soveral
Master
Level 3:
President:
Answers
566
Questions
Helped
276058
Points
1995
From TI FAQs:
What troubleshooting can I try if the TI graphing calculator will not turn on?
For the TI-83 Plus Family, TI-84 Plus Family:
Caution: The resets described in these troubleshooting steps will cause a loss of applications, programs and data. If at all possible please create a backup using TI Connect™ first.
  1. Try a new set of AAA batteries.
  2. Adjust the contrast by pressing and releasing the [2nd] key followed by pressing and releasing the up arrow; repeat as necessary. To adjust or lighten the display, use the down arrow.
  3. Remove one of the AAA batteries. Press and hold the [CLEAR] key. While holding [CLEAR], reinsert the AAA battery and then turn the calculator on. The calculator should display the message "RAM Cleared". Release the [CLEAR] key and then press it one more time to remove the message.
  4. Remove one of the AAA batteries. Press and hold the [DEL] key. While holding [DEL], reinsert the AAA battery and then turn the calculator on. The calculator should display "Waiting...Please install calculator software now". Follow the instructions for the TI-83 family or TI-84 Plus family to reinstall the calculator operating system.
  5. Remove all of the batteries including the round lithium battery for 5 minutes. After the 5 minute period, reinsert all of the batteries and turn the calculator on. Adjust the contrast if necessary.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Aug 26, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
577
Points
Maybe you changed the screen contrast "2nd function + up/down" if you make it really bright you can't see a thing, seriously. Hold down 2ndfunc + down see if it darkens the readout so you can see the screen again.
My son went to turn on his TI-84 Plus calculator and it wouldn't go on. He had used it in class a few hours before. We tried replacing the AAA batteries, but that didn't work. We tried replacing the...
TI calculators have an annoying habit of dimming the screen when the batteries are changed so that it appears as if the calculator isn't turning on. Turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible.
If this doesn't do it, please reply to this post and we can go on from there.
5helpful
My TI-84 plus silver edition calculator is not responding. Whenever I press a button it takes forever to put it up on the screen or it doesn't work at all! I need some serious help with this. I tried...
Hi purzabumafu8,
You need to re-install the Ti 84 Plus OS on both calculators, ASAP!!! You can fix these problems by installing the newest Ti 84 Plus 2.55v. MP OS, operating system. Use fresh batteries.
If you have a friend that has a Ti 84 Plus or, Ti 84 Plus Silver Edition you can connect the two calculators together through the USB or, IO link ports. Then they can send you a copy of their OS, while you receive it on your Ti 84 Plus. Hopefully, your friend will have Ti84 Plus 2.55v. MP OS on their calculator or, it might not work. Link the two calculator together through the USB or, IO link ports with the proper cable. If don't have another reliable calculator to connect too, you'll have to connect the calculator to a computer to download the OS, goto Procedure 5. If your downloading off another calculator goto Procedure 1.
Important Note: Never disconnect a TI Connectivity Cable during a transfer. Lost of power during installation of OS will destroy your calculator.
Procedure1. Procedure to linking to another calculator.
On their calculator press, [2nd][Link][G] [Right-Arrow]. On your calculator press, [2nd] [Link] [Right-Arrow] [Enter] and, then press [ENTER] on their calculator too. Their calculator should say, "TRANSMIT" and, your's will say "Receiving." Then on both calculators once transfer is complete press, [2nd][MODE] to quit and, return to the Home screen. If the OS was transferred then your finished with these procedures. If your calculator won't turn on or, is locked up try the Procedure 2, below.
Procedure 2.
"Waiting...Please install calculator software now". If calculator did not turn on or, is still locked up goto Procedure 3, unless already did Procedure 3, then goto Procedure 4. If you calculator does come on and is responding and, your connect to another calculator goto Procedure 1. If you calculator does come on and is responding and, your connect to a computer goto Procedure 7.
Procedure 3.
Remove all of the batteries including the round lithium battery for 5 minutes. After the 5 minute period, reinsert all of the batteries and turn the calculator on. Adjust the contrast if necessary. Goto Procedure 2.
Procedure 4.
If the above process did not work. Try re-doing the Procedure 2, and, this time extend the time in Procedure 3, by 5 minutes to 10 minutes before you put all the batteries back in the calculator. These calculators can be a little stubborn at times so, keep trying Procedure 2.
Procedure 5.
If you can't find a calculator to connect too, you can connect your Ti 84 Plus to a computer that has Ti Connect software on it. If you need to connect your Ti 84 Plus to a computer make sure the Ti Connect software is operating properly. You do not want any hang-ups while installing the Ti 84 Plus OS.
Procedure 6. Procedure to installing the latest Ti84 Plus 2.55v. MP OS. TI OSDownloader does not always install the latest OS.
You can get the latest copy of Ti84 Plus 2.55v. MP OS and, guidebook by going to the Texas Instruments web site. You can get to that site instantly by clicking, "Ti 84 Plus 2.55v. MP OS!" Once your at the Ti site click the Download Item, "Ti84 Plus family operating system". Next you can login or, click "continue as guest". I'd would click the "continue as guest". Once you have click, "continue as guest" the Ti84 Plus family operating system will download to you.
Next, click "SAVE" and then a window to a folder will pop up. It is probably a window to a folder that you download too. If so, you may want to change it and, save to this folder, "My Documents \ My TI Data \ Downloads". You can also go back and, download the Ti 84 Plus guidebook too, if needed. If your calculator will not turn on or, is locked up goto Procedure 2. Or else goto Procedure 7.
Procedure 7.
Link your computer and, Ti 84 Plus calculator with the USB cable or, Direct Black Link cable that came with the Ti 84 Plus calculator. Next, drag the Ti 84 Plus 2.55v MP OS that you saved earlier in "My Documents \ My TI Data \ Downloads" out of that folder and, drop it in the "Ti Connect" icon on the desktop. Click, "Continue" when the "Erase Warning" pops up and, the new Ti 84 Plus 2.55v MP OS will begin to install. Next, the Ti Device window should pop up and, highlight the port when it finds what your Ti 84 Plus is using, USB1 cable or, Direct Black COM1.
When the Ti Device Explorer finds and, highlights your calculator's information click, "Select." Then click, "Yes" when the next window shows up with your calculator's information and, the OS will continue to download. Upon completion the newest Ti 84 Plus 2.55v. MP OS will be installed.
If you run into any trouble with software or, drivers just comment to what failed at this posting and, I'll be glad to help you.
1helpful
I'm a senior and have had my TI-84 plus for four years now. I just went back to school and tried to use my calculater for the first time in two weeks but it won't turn on. I've switched the batteries...
If this doesn't do it, please reply to this post and we'll try something else.
9helpful
When i turn on my ti-84 the screen is black - i have changed the batteries
Turn the calculator on. Press and release the 2ND key. Press and hold the down-arrow key until the screen lightens. If you go too far, press and release 2ND, then press and hold up-arrow.
19helpful
Dark screen on my TI-84 plus. What to do?
Press the 2nd key (yellow one) and then press the UP arrow to increase brightness or down to decrease but seems like you to need to press UP arrow.
1helpful
School disabled all my apps - now what?
Use the link cable and link your calculator to a calculator where the apps haven't been disabled. From the other calculator, send a program or an app and that should enable the apps on your calculator
5helpful
Deleted y column in TABLE
I do not think that you can DELETE it, you probably just cleared the equation, just put another equation into Y=, and it will work.
otherwise, if you don't have any programs you need or so... just press 2nd +
Scroll down to reset, and press clear RAM
26helpful
2answers
Reset
First, turn it on. Once the calculator is on, press the "2ND" key (I believe it is a blue key in the ti-84 plus silver edition). Now press the plus key (+). A little above that key, you should see the word "mem." When you see the screen titled MEMORY, move the cursor all the way down to the option that says "Reset." From here, you can choose to reset either the RAM memory, or the factory settings. The factory settings are the "Defaults" option. I hope this helps.
Thanks.
4helpful
I accidentally dimmed my display screen, how do I fix it?
Hold the 2nd function button down while pressing the up arrow to darken the screen, alternatively hold the down button to brighten.
4answers
RAM Cleared
This is kinda a weird situation. Because it's usually the other way around. Your ram will clear if your calculator is frozen. So take out all 5 batteries from the back. Even the back up battery. Then reset it again. 2nd then + then 7 then 1 Then 2. Good luck.
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Jerry Naidoo
Paul Bade
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
