Boating Logo
R
Ross Bucknall Posted on Jul 09, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a 90hp yamaha 2 stroke should there be water coming out off the 2 exhaust holes on the shaft
Gary F
Level 2:
Sergeant:
  • Expert 258 Answers
  • Posted on Jul 09, 2019
Gary F
Expert
Level 2:
Sergeant:
Answers
258
Questions
Helped
66094
Points
672
5 Related Answers
Anonymous
  • Posted on Feb 28, 2009
SOURCE: exhaust gets red
could b obstruction in exhaust put hand couple of inches behind exhaust and rev it up should have good amount of exhaus coming out.if it is no obstruction there check timing
Anonymous
  • 97 Answers
  • Posted on Aug 06, 2009
SOURCE: what is the maximum rpm for 50 yamaha 2 stroke
max operating rpm 4500-5500 see www.broadwaterboating.com.au/outboards/335_Yamaha_50hp_Mid_Range_2-Stroke.php for complete specifications. Hope this helps
Anonymous
  • Posted on Nov 16, 2009
SOURCE: i have a 90hp yamaha two stroke, makes a grinding
I had the same thing happen to me this weekend. I tried to slam it in reverse after my dog fell off and it sounds like yours. Have you found anything about the issue?
Anonymous
  • 53 Answers
  • Posted on Nov 18, 2009
SOURCE: I have a 2002 ox66 Yamaha 2 stroke 250 hp std
Prop shaft. You have to remove the bearing housing cap. reference number 70. Remove the bearing housing. reference number 60. The bearing housing will need to be pulled out buy using a puller. If it was in salt water it can be difficult. Pull the prop shaft and clutch dog assembly.
Testimonial: "Thanks i will try."
Anonymous
  • Posted on Apr 13, 2011
SOURCE: Where is pee hole on 1980 Mercury 4 HP 2cyl 2 stroke
Hey I just got the same motor and actually have the same exact concerns. Have you found any answers?
2005 Yamaha 15HP leaks oil out of the exhaust hole
Sounds like a head gasket, worn valve gasket, as my first guess.
1helpful
My 90hp Mariner 2 stroke outboard will only turn over when plugs removed
Hey Bryan,
When you turn the engine over with the plugs out, does gas or other liquids come out of the spark plug holes?
reply to me..
Thanks
Jun 13, 2017 • Boating
Just changed the impeller on my 2012 Yamaha 90hp outboard, but no water coming out of the tell tale. what could be wrong?
howd the pump drive shaft nib look when you replaced the old one ??? if it was worn round and not "D" shaped it wont drive the new pump
Aug 12, 2016 • Boating
1982 55 yamaha outboard ,water not coming out the water pump hole in strenght
First thing to check: Disconnect the tiny hose between the check outlet and the engine. Disconnect it at the engine side.
With an airgun, blow in the check hole from outside to engine side.
With an airgun, blow out the engine connection.
Start the engine, check waterflow out of the engine connector. If water, reconnect the hose and check the water at the checkpoint.
If still no water at the engine connection: replace the impeller!
Yamaha 6L5 , 3hp , 1989
Water pump impellers wear out and need replacement.
Feb 04, 2018 • Boating
1helpful
I have an ancient yamaha 4hp outboard two stroke.... it has a dammaged aluminum housing on the leg on the left hand side directly below the motor. Cant tell what might have used to be there....Can see the...
sounds like this is the access hole to allow you to reach the clamp which hold the gear selector rods together, even if you dont have gears this hatch was incorporated in the caseing you could cver this hole up without causing any problems but dont make a permenant fix as you may need to use this access hole at sometime.
I have a 90hp yamaha two stroke, makes a grinding
Nov 15, 2009 • Boating
2helpful
Oily watery stuff coming out off the exhaust, oil pump is set ok
is this bike a yamaha rd 350 twin cylinder 2 stroke? if so, its air cooled and you should not be getting a ltr of water.. but it is common for them to have a "oily" fluid come out the exhaust because it is a 2 stroke. but not alot. it comes from the engine not burning all the oil gas mix. does the engine spit and sputter? make sure there is no water in the tank, make sure the air filter is clean and buy hotter spark plugs. also adjusting the fuel air mixture may help. hope this helps...
Top Yamaha Boating Experts
neil
Stan Ford
Are you a Yamaha Boating Expert? Answer questions, earn points and help others
