I have a Craftsmen LT 3000 Lawn Tractor, 3 or 4 years old. While driving it the other day, the engine cut off. I thought I had hit a rock and it had stalled until I realized the blade was not engaged. I was just driving over to where I needed to start mowing. The mower will not even try to crank. I charged the battery hoping that was all it was but I am afraid I have locked up the motor. How do I know if I have locked the 20HP intek ohv small engine up? I changed the oil at the beginning of this season and checked it since this has happened. The oil level is fine.
That Briggs engine is not a good engine it has a weak governor gear that is known to come apart for no reason what so ever it may have done so and some of the parts stopped the cam gear from turning. Good luck!
Testimonial: "Thanks. I have a book that will help me check this governor gear. I will check this and repost."
Yes I do hear a click but it will not even try to turn over the engine. The battery is only three months old so I do not think that is the problem.
I will try to short it out and see if it works. Thanks
Does the starter engage? When you turn the key, do you hear a "click"?
I doubt you've locked up the engine. Do you know how to short the solenoid with a screw driver? If so try that to see if your starter tries to engage. If it does then I would suspect that you have a bad starter solenoid.
Report back and we'll go from there.
