A message flashed at the bottom of the screen saying TV was powering down and viewer should check to be sure air flow was not obstructed. This set was donated to our facility in July, with no manual or other instructions, so I haven't a clue as to what to do next.
Mitsubishi has had some problems with these sets with the lamp cartridge(google the model number and look for how to replace lamp instructions) On some of the lamp cartridges they covered several openings with a fine screen like material---one is narrow and completely blocks up with dust---this will trigger the air flow message--if you get the lamp out and this screen is blocked, carefully clean the dirt off with a brush---if you don't get it soon enough it will kill the lamp----the replacement lamps for these sets use a bigger mesh that does not block with dirt---it blocks because there is a fan the pulls air and dirt into the set to cool the lamp during operation.
NEVER TOUCH THE FRONT GLASS OF THE LAMP WITH YOUR HAND
I do this here for free so if this helps you give me a vote here.
