HP LaserJet 2550n Printer Logo
Posted on Aug 24, 2009
The orange light on my printer is flashing next to the triangle symbol with an exclamation point in it. What does this mean and how do I fix?
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Sep 11, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
2168
Points
It is out of paper.
I have a triangle error symbol in the lower right hand side of my printer, it has a lightning bolt inside of the symbol........what does this mean?
Canon printer light blinking error is a common error. Each printer features a flashing light to indicate its functionality. With Canon printers, you have flashing green and orange lights to inform you of any existing problems. It is suggested to carefully observe the number of flashes or the pattern of blinking lights as this will help you to understand the problem. And depending on the pattern, you can follow our canon printer troubleshooting guide mentioned below to solve that issue.
What does triangle with lightning bolt mean on Canon printer?
The orange triangle with the lightning bolt comes on when the printer is plugged in. The white light above the power button is on, but the printer is otherwise dead.
What does the orange triangle mean on my Canon printer?
When a printer error occurs, the Alarm lamp flashes orange as shown below. The number of flashes indicates the type of error that has occurred. Count the flashes and take the appropriate action to correct the error. Power Lamp Flashes Green.
What does the triangle symbol mean on my canon printer?
Seeing a yellow triangle with an exclamation mark usually indicates that a hardware device needs to be updated. If you are seeing the mark in Device Manager, we recommend checking the device status of the printer driver.
What does the flashing yellow light mean on Canon printer?
When an error occurs in printing such as the machine is out of paper or paper is jammed, a troubleshooting message is displayed automatically. Take the appropriate action described in the message. When an error occurs, the Alarm lamp flashes orange and a Support Code (error number) is displayed on the computer screen.
Paper could be lodged in printer somewhere. Check front and rear area where paper runs through. Then unplug and try to reset
1helpful
WHAT THE SYMBOLS MEAN
From left to right:
(Lights)
Exclamation point: Error
Weird Monitor beat symbol: Jam
Paper: Out of paper
Toner (Triangle leading down to dot pyramid): Toner refill
Lightbulb: ready
(buttons)
Greenish Play button (square with triangle): Continue
Red button with x: Stop/Cancel
Dell 2230 User Guide Page 1
7helpful
My printer has an orange light showing next to a symbol which looks like a beaker with a triangle of 6 dots in it. What does this symbol mean? Thanks
It the light is solid then the toner is low. If the light is blinking the toner cartridge is missing and has been removed
2helpful
2answers
Orange light is flashing
Unplug the power cord for 10 seconds
1helpful
HP P2015DN
If just the triangle with the exclamation point in it is flashing, the printer is sensing the cartridge door is open
5helpful
Error light
it detected an error. try opening the paper tray to see if there are paper jammed. take out the the drum with powder and and turn off the printer. then put all back in place and turn on printer. usually the hp network printer is installed on the server. check on the server if you see on error from the hp driver program.
good luck.
k24674
Grand Canyon Tech
Grand Canyon Tech
