Home Logo
t
terry grace Posted on Jul 09, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need an instalation guide for the maxx iris shower 34 x34 x 76
Tom Chichester
Level 3:
Top Expert:
  • Home Master 62,329 Answers
  • Posted on Mar 28, 2021
Tom Chichester
Home Master
Level 3:
Top Expert:
Answers
62329
Questions
0
Helped
672237
Points
975369
Contact Maxx directly to request the information.
1 Related Answer
Anonymous
  • 50 Answers
  • Posted on Mar 12, 2010
SOURCE: We have a Maxx shower SA9592-02. The water comes
take a philips screw driver and take the screw out and flip the hot cold handle that should fix your problem
Hello..is this where i ask questions for MAXX products
You appear to have three Posts asking about MAXX. Better to have one Question giving all the information.
https://www.fixya.com/users/lawrence-rose-52385
Steve Pack has given you the answer. Here is another, but note, we are FIXYA not MAXX. Bases seem easy to find.
https://www.google.com/search?q=maax+shower+base
Hi I need to repair my MAXX product shower base or look for a replacement but i can't see dimensions sizes for the plastic base
Google maxx shower base they come on Home depot just measure the base . . Its shows differant sizes .
Nov 02, 2023 • Home
Moldy caulking in recessed seam
Just buy a bottle of Tilex Mould Spray.
Also you need to dry the caulk and tiles each time you use it and leave the door open so it dries out between uses.
https://maax.com/product/davana-neo-angle-38-x-38-x-75-in-8mm-pivot-shower-door-for-corner-installation/139315/139315-900-084-000
Nov 22, 2021 • Home
2answers
E:61:30 error message
this error is
"Reset position detect error when stepper iris is initialized"
Turn on the power and set to T (telephoto) end by rotating the
ZOOM manual ring. While observing the iris blades in the
lens, turn on the power again and check the iris blades in the
lens work properly. Inspect the iris drive motor of lens drive
block (Pin qh to ql of CN6602 on the VC-582 board), when
the iris does not operate. Inspect the iris reset sensor of lens
drive block (Pin qd to qg of CN6602 on the VC-582 board),
when the iris operate.
if you need more help you can download the factory service manual from the below link:
http://goo.gl/Wt4pr
Good Luck
1helpful
Ceiling mounted shower head (Danze) leaks water for a good 30-40 seconds long after being turned off
you really can not because of the overhead piping holds lots of water and so does this big head....that is just normal for these things...i am a licensed plumber for over 34 years and have done these...its just draining out all the overhead water....
Oct 06, 2012 • Danze Home
2helpful
Trying to install a Maxx Neo-angle corner shower with prefab plastic base. No description as to how to affix the base to wall (no holes or tabs to screw into the studs)... Only instruction is...
Hello. You're not going to believe this, but MAXX says that the drain and the wall pannels (glued) will keep it in place if the floor is properly leveled before. Personally, when I installed mine (model 105525 - exactly the same installation instructions) I used silicone on the base at each stud area. it's secure, but not permanent, and won't allow an area for a crack to form.
Hope this helps.
Mar 08, 2010 • Home
Top Home Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Home Expert? Answer questions, earn points and help others
