Motorola Mobility RAZR V3 Logo
Posted on Aug 24, 2009
I am getting a random error message on my Motorola RAZR V3 Celluar phone. It says I should insert the SIM. The message goes away when I reboot, but it reappears. Can anyone help?
Anonymous
Level 1:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Aug 24, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
5
Questions
0
Helped
1353
Points
15
Remove the back cover, battery and SIM card. Wipe the SIM and the pins where the SIM card is inserted with a cloth if u can. Reinsert simcard, battery and back cover.
I have a network busy message on a RAZR V3 when trying to make a call. I can send text messages and the sim works fine in another phone. When I call the phone it goes straight to voicemail.
Turn off your phone then take the battery and sim car out for ten seconds replace then reboot your phone. This performs a soft reset. If it still doesn't work back as much stuff up as possible (contacts, pictures, apps, ect.) and perform a hard reset.
Good Luck!
3answers
Unlock razr v3
Which Country Network Lock now?
You can get the Unlock code and Unlock Instructions at
moz-screenshot-7.pnghttp://www.theunlockspot.com/motorola-razr-v3/rs10wp9/
follow the Instructions and Unlock it step by step:
Motorola RAZR V3 Unlocking Instructions Warning : Do not enter any wrong unlock codes on your Motorola RAZR V3 mobile phones. If you enter over a certain amount of wrong unlock codes on your Motorola RAZR V3 mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch ON your Motorola RAZR V3 with a NOT ACCEPTED SIM Card,
2 - Phone will display "Enter Special Code",
3 - You can now enter the Unlock Code.
NOT ACCEPTED: We mean, to use a sim card from a network other than the network your Motorola RAZR V3 is locked to.
WARNING: If one of theses messages appear :
- "Contact Service Provider"
- "Tampert Alter"
- "Wait before enter special Code"
- "Contact Service'
It's because you or somebody already entered too many wrong codes, you just have to leave the Motorola RAZR V3 ON with the errors message and after 40 minutes to 2 hours the message "Enter Code Special" will appear again!
My phone got locked and i tried everything to unlock it but noting works, its a motorola V3 please help me asap
If you're getting "Contact Service Provider" error message, then you simply need to leave the phone on with a SIM card on it for about 8-12hrs. This should reset the unlock counter of the phone. Unlock Motorola RAZR V3
1helpful
Have motorola razr V3, how do I transfer text messages to sim rea
Hi
Thanks for using FixYa. If you have Motorola phone tools installed in your system, then you can directly copy the messages from the phone to your Computer. And, if you are unable to see the messages through the SIM card reader then the messages would be in the phone and not SIM.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
2answers
Motorola razr v3 not catching signal
Have you used the external antenna port? If this is damaged it renders phone useless. Somehow connected to main antenna.
Insert Sim Card Error
well the back plate made need to be tighten or replace the housing
Insert Sim while charging
you may have a frimware problem.....first try and get the phone service to see if that corrects the error......or you may need to get the phone reflash.
Insert sim card
you need to have the phone firmware reflash...take the phones to a professional mobile repair store and have them fix
Top Motorola Mobility Cell Phones Experts
AFIFUL HAQUE MUFTI...
Level 1 Expert
vince
john h
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
