SOURCE: red light flashes four times
4 red light flashes normally means there is a problem with the fan. Time to make a service call.
SOURCE: sony bravia kdl40s2010u
A 4 flash indicates you have a backlight problem. Either the backlight inverter boards have failed or you have a backlight that has failed in the LCD panel. You will need a technician to check the set to determine which is the problem.
SOURCE: Mitsubishi WS73713 - Now working - Timer light flashing.
hold menu button for 8 sec and then unplug for 1 minute. then when you plug it back in it will work after 1 minute
SOURCE: shuts off then red light indicator flashes, disconnected all speakers but still wont work
Hi, this is a power board issue. remove the cover and make sure that this unit doesn't have blow fuse. if the fuse is fine, you will then need to replace the integrated power/ main board.
SOURCE: tvstopped working, green power light comes on, red light flashing
Most likely it has a power supply module problem. Have it looked at by a qualified service company.
