G
Gail Griffin Posted on Jul 09, 2019
When I turn it on it only hum - Audio Players & Recorders
What could be the problem with the goodman a/c if you turn it on and you hear a hummin but the fan dont turn on
capacitor? will hum if contactor pulled in but no ac power. will hum if contactor pulled in and bad capacitor. depends on how lowd the hum is. loud hum prolly equals bad capacitor
Humming noise when i turn the key on in the morning
power steering pump make humming noise and alternator with bad shaft bearing make noise.
Jacuzzi 1hp hums won't turn on
If your motor is turned on and just hums then it is bad and will need to be replaced.
Rod
US Parts Center
888-521-6183
Pump hums
hums as in it did not turn on and pump water or hums like it should be running great?
Rod
US Parts Center
888-521-6183
2helpful
2answers
When i turn on the power for my speakers it hums like crazy
do they hum when you unplug the audio jack from the PC?
If they stop humming when disconnected the problem will be down to a bad earth connection on the motherboard, or a failing power supply (rectifier circuit)
Humming is normally a result of voltage potential and the 50hz frequency in the mains.
Hope this helps
Dishrag caught un disposal, pulled it out, blades turn, it just hums, it hums even when switch is turned on off!!
If cutter disk turns freely and motor hums, then motor winding has gone bad.
The humming sound means motor is overheating and will stop humming.
I wrote ez garbage disposal replacement steps from days when I worked apartment maintenance.
http://www.fixya.com/support/r7929008-replace_garbage_disposal
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on disposal or any do-it-yourself project.
Fixya is always less expensive than a service call.
When turning up the volume speakers start to humn. Tried on all inputs still humming. Sound comes out but humming is there. Humming only stop when turning the volume all the way down.
You need to add a "ground lift" to the power cord to your system. What you're hearing is a 60 cycle hum (electricity) from house power.
3helpful
2answers
Hums when turned on-won't turn over
belt may have broke. if you are hearing a humming sound . thats the motor .whitch is good, sounds like the belt broke or slipped off.
Air Handler Blower Unit Humming
More then likely it's the transformer. It may be getting weak. I've seen them hum/vibrate almost new and last for years. It's more an annoyance than anything.
 Grubhead
Grubhead
SmartAviator
SmartAviator
