I have everything hooked up as far as the amp and stereo. Now I just have to hook up the battery, and the fuse is not in the holder. which do I do First? I Know Last step is hook up Negative post.
1. connect positive post
2. connect fuse in holder
3. connect negative post
or
1. connect fuse
2. connect positive post
3. connect negative
or do I put the fuse in last????????
Hook up the battery, (the negative post) and then put the fuse in. This is the best choice because if you put in the fuse and then put the negative post back in and the wires slip when putting in the negative post, the fuse might blow due to the sparks. You will then need to get another fuse, which also mean sending more money.
