Ovens Logo
Posted on Aug 24, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
FRIGIDAIRE STOVE MODEL FEF316BSC I WAS BAKING
FRIGIDAIRE STOVE MODEL FEF316BSC I WAS BAKING ANDLOUD POP FROM OVEN ELEMENT BURNING
Anonymous
Level 3:
  • Master 725 Answers
  • Posted on Aug 24, 2009
Anonymous
Master
Level 3:
Answers
725
Questions
0
Helped
167348
Points
1617
Don't worry! Your element probably blew out. It's no big deal. It happens. Call us for parts. 9728590929. It's really a simple repair, probably one of the easiest to do. Hope this helps!
Top oven element on shacklock stove. Does it work on bake. My one only works on grill. What does that mean
Quite normal...top element is for grill/broil only. Bottom element is for bake only. If the grill element were to come on during baking a cake it'd burn the top of your cake to a crisp.
Some grill/broil elements cook at 500-700 degrees.
Jun 25, 2023 • Ovens
1helpful
Oven temperature will not cycle
How To Fix Oven With Little or No Heat When Baking ...
www.partselect.com/Repair/Range-Stove-Oven/No-Heat-When-Baking/
Repairing a range, oven, or stove can seem like a big task, but our ... Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake... If the bake element isn't working, the oven may not reach the set temperature or ...If the element appears to look normal, then turn the oven on to a bake ...
Electric Stove Repair ' Electric Oven Repair Manual ...
www.appliancerepair.net/oven-repair-4.html
Inside the oven, the heating element is called a "bake" or "broil" element. ... To maintain a set temperature in an electric cooktop, the element is cycled on ... Do not put any cleaning agents or solvents directly on heater elements or surface units. ... A switch will show no continuity when off and good continuity when turned on.
Electric Oven Will Not Heat ' RemoveandReplace.com
removeandreplace.com/2015/.../oven-not-heating-how-to-fix-range-repa...
Aug 24, 2015 - The issue is most likely a bad internal fuse, oven temp sensor, ... oven replacement parts ... Bake and Broil Element Test - Electric Oven Repair ... Dryer Spins But No Heat - How To Troubleshoot Dryer is turning the drum but ... If your dishwasher is completing the wash cycle but will not dry your dishes, we ...
Oven Temperature Not Accurate - Repair Parts ...
My wife heard a loud pop while baking, the oven will no longer bake, the stove top still works so does the clock ect. Elements are fine just don't warm up. I have a kenmore 790, is there a internal fuse...
Check the baking element, sometimes these will make a popping sound if they burn into. Also a lot of your components are behind the knob/clock area.
Feb 25, 2010 • Ovens
Bake element
It may have also Blown the Fuse, to the element, in the stove itself.
6helpful
Frigidaire ES200/300 316257123
look for a shorted bake element .. you should be able to see where it poped. ( some times ) if you have ohm meter you can ck for an open element . **** //
Frigidaire oven will not heat up
Not popping sound you heard was the element popping take care of it out did you take your fingers and go round the outside of the element you'll find a whole the place that element you get your heat back
My oven wont work?
check your breaker to see if it tripped,sometimes the breaker will trip and one or the other wont work.meaning the stove top or oven.also check and see if their are any breaks or burn spots in bake element and your broil element.
1helpful
Bake or broil does not work
if an element itself had shorted it would not stop the other from working and you could inspect each element and see blistering as evidence.the pop you heard has to be in common with both elements but not the cook top[burners]so thats going to be the wiring in the back of range, or switching,[thermostat,clock timer or oven selector switch,depends on which model you have]you will have to pull range and remove back pannels.you will find an obivous burn't connection.too repair all new connections must be clean and tight,or will burn again.
2answers
My ge spectra stove bake element is not heating
I have a GE Spectra stove. The top element over heated and broke in half.
Top Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you an Oven Expert? Answer questions, earn points and help others
