My Mitsubishi WS-55819 TV has double vision. I am unable to clear it up under the convergence section. It was going in and out of a clear picture but now it doesn't go back to clear.
Ur tv is 100% have a convergence problems,it dead.The tv colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
you ned to replace both convergence ICs they are STK392-570 you can get replacement ICs at the following link with free installation instructions. http://servicemanuals.vstore.ca/
Could be a problem with the convergence IC's or a resistor(s) / capacitor(s) around the IC's. I suggest calling a service guy and getting the TV fixed.
Convergence ICs are bad need to be replaced. You will need to replace both of them also check the resistors right next to the IC often 1 or 2 of them burn out when the IC goes.
CEM-NO, BOTH ICS' WORK ALL 3 CRT YOKES.YOU EITHER NEED TO REALIGN THE RED IN FACTORY CONVERGENCE MODE OR YOU HAVE A RESISTOR THAT HAS FAILED.THE LATTER YOU MAY ACTUALLY BE ABLE TO SEE IF YOU LOOK CLOSELY.OH, ALWAYS DOUBLE CK. YOUR SOLDER CONNCETIONS.GOOD LUCK. JOE TV
