Quinny Freestyle 3 XL Stroller Logo
Posted on Aug 24, 2009
Is it heavy to handle?
Could you please indicate me the specifications of this stroller (W, L and l and also the weight)
Thank you.
Regards
Anonymous
Level 1:
Problem Solver:
  • Contributor 14 Answers
  • Posted on Aug 25, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
14
Questions
0
Helped
7500
Points
24
Dimensions & weight
  • Seat: 40 x 24 x 47 cm (WxDxH, H=backrest)
  • Dimensions chassis folded: 100 x 69 x 39 cm. (LxWxH) (including wheels)
  • Dimensions ready for use: 118 x 69 x 105 cm. (LxWxH)
  • Weight: 15.6 kg.
http://www.babycare.nl/quinny-freestyle-3xl-comfort-black-p-102.html?language=en&name=Quinny%20Freestyle%203XL%20Comfort%20black
Manitowoc Ice Machine. WHAT IS THE WEIGHT OF THE MODEL MACHINE JD0202A please?
How heavy is a Manitowoc ice machine?
America's #1 Selling Ice Machines. Weight: 114 lbs. 208-230/60/1 also available. From under counter, to auto dispensing, Manitowoc offers 17 commercial models with daily output from 45 lbs.
https://www.google.com/search?q=Manitowoc+JD0202A+weight
2answers
Peg perego milano stroller
Here is peg perego's list of stroller manuals but I don't see Milano, there must be a different model name somewhere on the stroller. I will keep digging.
Mar 03, 2008 • Baby Gear
2answers
Fixating mechanism in handle is broken
Ok, how is the frame broken ?
what is it made off ?
please reply with more info.
2answers
My scales turn on but still do not work.
Please first place an excercise weight on the scale . The scale might be attempting to calibrate it's sensors before being able to properly weight unknown items. After 30 seconds, it might ask you for some kind of input to specify the weight of the test item. Otherwise, you'll need to factory reset your scale.
Thank you.
Top heavy, need wheel wieghts
Quinny Zapp only suitable for 2 years and under no such thing as a wheel weights and if there was you'd need 10Kg!!!. You need to move on to a 4 wheel like a Bugaboo Bee
Hello, I bought quinny buzz from the netherlands.then we moved to USA.during the travelling the flight company broke the stroller's handle.after flight the handle was broken in the middle but the wire...
hi this is replaceable but you have to replace the handle and not just the cable easy to do look at
this video for the mothercare my3/4 (same handle as quinny)
http://www.youtube.com/watch?v=viSDFutpAOY
parts are available direct from quinny
The arm between the handles has broken, on the plastic swirl part,can I buy a replacement part?
Hi, no this is not replaceable but you can buy used frames on Ebay very cheaply. I know someone who just put black tape around this bar which then works fine. hope this helps you? If so please leave feedack for me. Thank you with regards Marie
1helpful
What are the dimensions of the bebecar m city?
The details are as follows ;-
1. Chassis folded size - 36.6 in X 20.5 in X 8.7 in
(93cm X52cm X 22cm)
2. Chassis weight - 25 lbs (11.4 Kg)
3. Carrycot weight - 15 lbs (7 Kg)
4. Seat weight - 13 lbs (6 Kg)
5. Seat width - 13.4 in (34 cm)
6. Handle height - 37-42.9 in
7. Wheels - Swivel
8. TSC - Yes
Good Luck!!
Thanks!!
Quinny buzz
hello lillups:
This does not sound good at all: does the stroller tip toward you or forward? Sometimes, especially with very small children, a stroller might tip toward you if there is excessive weight on the handle area.
Let me know if you have any further questions!
StrollerInfo
www.StrollerInfo.com
[email protected]
1helpful
Broken handle
The Zooper.com website has a service request form in which you can request replacement parts. Look under FAQ.
Top Quinny Baby Gear Experts
Jennifer Rock
Jennifer Rock
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Are you a Quinny Baby Gear Expert? Answer questions, earn points and help others
