Note:-
Generic Host Process for Win32 Services or svchost.exe is a legal and essential component of Windows which is used to host services which run from dynamic-link libraries (DLLs).
Please note that legal svchost.exe should reside in Windows\System32 folder and should not appear in startup list.
If it does appear, do a Malware/spyware/virus scan on your PC.
Then after you do all updates, download and run the free malware bytes version and run a full scan. This software is free to run but if you want the full version it will cost around 30 to 40 bucks.
This should help you update the hardware drivers for you computer and also eliminate any spyware that may be using up your memory or making your computer work harder than it should.
Generic Host Process for Win32 Services Error is a broad issue.microsoft has a patch for this issue.You may download the patch KB894391, to fix this issue.
or
Alternatively you can do windows update manually (Note that the
above patch solution and the following windows update solution works
only on PC/computer running genuine Windows and not pirated versions):
Go to the start menu
Right click “My computer”
Click “properties” then the “automatic updates” tab
Choose “turn off automatic updates”
Restart your computer
Go back to start menu and in all programs go to “windows update” you have to be connected to the internet
Manually update windows
Turn your automatic updates back on
You can also try the following solutions to fix this error:
Solution 2:
Go to Run and type regedit
Navigate to HKEY_LOCAL_MACHINE >> SYSTEM >>
CurrentControlSet >> Services >> Browser >>
Parameter
Turn off the computer and the printer or the scanner.
Disconnect the printer or the scanner from the computer.
Restart the computer.
Install the compatible drivers and software for the printer or the scanner, and then reconnect the printer or the scanner to the computer.
4. 931852(http://support.microsoft.com/kb/931852/ ) Error messages when you start a Windows XP-based computer and then try to download Windows Updates
894391(http://support.microsoft.com/kb/894391/ ) You receive a "Generic Host Process" error message after you start the computer, or DBCS attachment file names are not displayed in Rich Text e-mail messages
819017(http://support.microsoft.com/kb/819017/ ) Long delay before files appear in My Computer in Windows XP
Hai,
svchost.exe is a system file, and it seems this file has got corrupted some how.
Try this, if u have the install CD of the OS, try boot from the CD
and go for new installation, in the final Partition selection part u will get a OS repair option. Press R and the system will repair the corrupted files to its original.
Then go for a full virus scan with an updated antivirus utility.
good luck
Rabby
