I tried to flash my k750i with the latest firmware but something went wrong in between.I know the procedure well, but it is not starting now.Please help me
Dont be panic.Just try flashing once again.I assume that you know the procedure well(If not, i can explain you).I also faced the problem twice.Dont skip any of the step and try....Please let me know your luck this time.I can still help you out if the problem exists further..;)
hi try to make to do again firmware update, something went wrong on the previous update. the orange light is on becaouse the printer firmware is wrong, is in the upgrade mode.
1. first install phoneix service 2. open it 3. In Phoenix, click File>Manage Connections. 4. Now click New. 5. Now select the type of cable you are using. If you are using DKE- 2, CA-53 [N-Series] cable, select USB. 6. Click Next. It will find your product and say FOUND. If it doesn't
find any, you can try changing your cable type by clicking Back. 7. Click Next and then Finish. 8. Now your cable type [USB] appears in the connection list. Select
it. Click APPLY and then CLOSE. 9. Now select File>Open Product. 10. A list of RM code will open. Select your phone's RM code. Like
RM-133 for Nokia N73. Click OK 11. Now select File>Scan Product. 12. Your phone's firmware info will appear at the extreme bottom of
the Phoenix window. 13. Now go to Flashing>Firmware Update. 14. A window will open. 15. On that window click Browse button [the one with three dots]. 16. A window will open with various products and various regions. Choose the region or country of your choice according to the language pack you want to install. 17. Click Ok. 18. Click Refurbish.
19. Now your actual flashing has started. Don't touch your phone or press any button until the flashing has finished. Also don't touch your data cable and your computer system. 20. At the end Phoenix will tell you to remove your phone as the
flashing has finished. 21. Now wait for your phone to reboot into latest firmware. 22. The flashing procedure takes 8-9 minutes, a lot faster than Nokia Software Updater. Flashing dead phones [Which show only white screen on startup] Note: You can install any firmware in dead phones whether it is latest and or the old one. 1. The procedure is the same for flashing Dead phones. 2. Start Phoenix. Connect your phone with USB Cable [phone is off at this time]. 3. Click File>Open Product. Select your RM code from the window that appears. Click OK. 4. Click File> Manage Connections. Select No Connection. Then
APPLY and CLOSE. 5. Now straight away click Flashing>Firmware Update. 6. A window will open. Click on Browse button [the one with 3 dots]. 7. A window will open with various products and various regions. Choose the region or country of your choice according to the language pack you want to install. 8. Check the option "Dead Phone USB Flashing". 9. Click Refurbish. 10. Flashing has started. 11. After some seconds flashing will pause asking you to turn your
phone ON. 12. Press POWER button of your phone until backlight comes up. 13. Flashing will proceed. 14. Your phone will automatically start when the flashing finishes. After finish you can safely remove your data cable AND THEN INSTALL E BUDDY>........
WARNING : This procedure can render your device dead, so do not try if your player is working fine.
The most important step of the whole process is to correctly
identify your device CONTROL CHIP and CPU, using wrong firmware or
flashing tool may cause damage to your device, unscrew and open your
device and write down all chip id's and motherboard numbers you see, you
can also try the EasyChips - firmware identification utility but it did not worked for me.
You will now need to download the correct firmware and flashing
utility for your device, visit sites below and search for your control
chip and cpu to download the firmware and flashing utility, you can also
post on user-forums to get help identifying the firmware :
In my case the chipset was Sunplus AJ262-V7 and the utility needed to flash it was FRM Pro.
Once identified you need to connect your device to computer
via USB in camera mode (Press A + OK button and plugin USB cord on
player), for Windows to identify this mode you will need camera drivers
you need to point Windows Found New Hardware Wizard to Driver
folder downloaded with the FRM Pro utility above, this will install the
first camera driver, for correct identification by flashing utility you
need to install a second camera driver - open Windows Hardware Manager
and install unidentified camera device drivers by pointing the driver
wizard to Driver folder used earlier.
Now install and launch FSM Pro flashing utility the new firmware.
1 .First downlad phoneix service 2 .open it 3. In Phoenix, click File>Manage Connections. 4. Now click New. 5. Now select the type of cable you are using. If you are using DKE- 2, CA-53 [N-Series] cable, select USB. 6. Click Next. It will find your product and say FOUND. If it doesn't
phone ON. 12. Press POWER button of your phone until backlight comes up. 13. Flashing will proceed. 14. Your phone will automatically start when the flashing finishes. After finish you can safely remove your data cable from h
1 .first download phoneix service 2 .open it 3. In Phoenix, click File>Manage Connections. 4. Now click New. 5. Now select the type of cable you are using. If you are using DKE- 2, CA-53 [N-Series] cable, select USB. 6. Click Next. It will find your product and say FOUND. If it doesn't
Before taking it to a service centre, you can try flashing the firmware. Download Update Service software from Sony ericsson site, connect your phone to your PC(follow the guide), run the software and perform the update. After it is done, unplug, turn on your phone. It should work now. If it still doesnt work, something is wrong with the hardware and you'll have to take it to a service centre.
