Hi,i presume that u cannot punch in the password as the keyboard is not working, except the Enter key, u can do two things, reset the bios, or repair the keyboard, by removing it and cleaning the contacts, to reset the BIOS, locate the small lethium battery, remove it and keep it outside for some time, then put it back,that will reset the BIOS.. try either of it.. let me know...
Save yourself some time and effort, if there are files on the drive take out the drive and copy them using an ide to usb adapter on a more modern pc. It is not worth the time and effort as W95 is no longer supported and it won't run any useful software (in my opinion).
I'm copying someone else's answer; I can't vouch for it. emove the main battery and mains power supply, hit the power switch to
drain any retained charge. then remove the cmos battery and short out
the contacts. the cmos battery is on the right under the panel at the
top of the keyboard, which can be popped out by gently levering it up
at the edges. the key board can then be folded clear, watch for the
ribbon cable under it that connects to the motherboard.
not too sure what u mean .
are you talking about bios password or os(windows)password.
it sounds to me like bios password cos if windows not set you just enter.
in which case you can try enter setup(bios)at start and select default values then save and exit;if it allows you .if it doesnt get back to me and can send you software to fix this via email.
