Air Tools & Compressors Logo
Anonymous Posted on Aug 24, 2009
My craftsman air compressor model 919 16737 1.1 hp 17 gal 150 psi won't build up any air pressure. It runs but sounds a little odd.
Fred Yearian
Level 3:
  • Master 5,603 Answers
  • Posted on Aug 24, 2009
Fred Yearian
Master
Level 3:
Answers
5603
Questions
Helped
2247449
Points
16162
Probably the check valve has failed. It apparently is where the pipe goes into the tank from the compressor.
1helpful
My compressor will not go over 20 psi i have a craftsman 921 4 gal 125 psi compressor and it will not build past 20 psi i do not know how to get to the pistons and stuff what do i do?
The problem with compressors not building pressure is usually a bad pressure switch or bad regulator. Does the motor shut off at 20psi or does it continue running and not build pressure? If the motor continues to run with no increase in pressure, the you should go over the machine looking for air leaks from your regulator back all the way to the motor. Any air leak while the compressor is running can cause the pressure to "peak" way before the intended shutoff that it is regulated to.
1 hp 3gal craftsman compressor will only build up to 20lbs pressure in tank. how much compression should single cyl have on compression stroke?
A piston in any engine should be around 100 psi I would guess. A Chevy 350 used to be around 150 psi. An air compressor that only pumps enough air to reach 20psi is obviously too low on compression. Nailers and the like need 80 or more psi. The intake valves may be shot, the unloader might be stuck or piston rings are worn.
Will not build up pressure
worn out pump on the compressor, or leak in tank.
Air pressure does not go over 25 psi I have taken the whole unit apart and check, relief valve,regulator,check valve. Pressure switch, Piston & Gasket. everything seem good I have taken the pressure...
Does it shut off at 25 psi or just keep running and never build more pressure than that? Also, did this come on gradually or suddenly? Also, was it being used regularly when it happened or had it been sitting for a while?
1helpful
Craftsman 30 Gal. 150 PSI Not building air over 45lbs
The compressor valve may have a faulty gasket or seal, and maybe leaking air internally. Or the compressor might be going downhill. You can try to replace the valve seal and see if that makes a difference, otherwise you need to replace the compressor.
5helpful
1helpful
4answers
Lack of pressure
My air compressor builds up to 40 psi and just keeps running, i have a craftsman 5 GAL, 1HP, 125 PSI and pressure goes up to 40 psi and dose not go any higher and on the other hand engine keeps running and dose not stop. Please advise?
Thanks.
Kia
Top Craftsman Air Tools & Compressors Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Steve Sweetleaf
Steve Sweetleaf
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
