My Starbucks Sirena espresso machine's steam wand stopped shooting out water when turned on. I have tried descaling numerous times but it doesn't help. Any suggestions on how to unclog the steam wand or help this problem??
The Sirena uses a combination valve with an electric switch attached internally that tells the pump to turn on when the steam valve is opened. I found on my own machine that as it got older, the switch and valve fell out of adjustment. The plastic knob could rotate the switch on, but not open the steam valve to allow the steam to flow. If you're handy, UNPLUG the machine and disassemble the steam valve. You'll be able to cycle it and observe the operation for adjustment. Also make sure the plastic knob isn't stripped internally and that the metal valve stem is actually turning with the knob.
High pressure air using a blowgun?
