GE front load # WCVH6800JWW is not spinning/draining the water out of my clothes... they are soaked coming out, and a lot of time it sets itself to "pause"..
Is it a clogged line, or maybe because it's not level?I think it leans forward a bit and needs to be shimmed or something.
SOURCE: soaking wet clothes
Harm, remove the lower panel and you will see the filter right in front. Unscrew the filter strainer and clean all the lint and debris. This machine has a pressure switch that won't allow a high spin if it detects water in the tub. Therefore you get these pauses and slow tumlbe. Try this and see if it's normal after cleaning the filter...Catriver...post back
sounds like there is a pumping/blockage problem. check the filter and all drain hoses/outlets. if all clear the pump may be faulty. is the drum turning at all?
SOURCE: Washer won't drain during the spin cycle
you would need to get to the pump,,,its probably a sock of some piece of clothing stuck in the pump. its under the washer.drano wont help with this sorry
SOURCE: I have a GE WBVH6240HWW Front load washer. I
i would try to clean the trap out at the bottom, there is a panel on the bottom take that off and clean out the trap, it looks like a turn dial, something like that has happend to me, it cant hurt to try
