I have a Denon AVR-2307CI.
Problem: HDMI does not always connect for a picture.
My set up: The HDMI from my cable box to my Denon then to the TV will only display a picture about every 2 out of 10 times.
Please advise on how to fix this problem.
Thank you!
In short, HDMI will not work. HDMI is riddled with issues, your's is just one of many! HDMI version 1.1,1.2,1.2a,&1.2b do not work 100% on any receiver. The current version is 1.3b and "so far" it works... Now the bad news; It's not just a software patch to fix the problem, it's a hardware issue as well. If your unit is still under warranty, the manufacturer will update hardware and software for you at N/C. If it's out of warranty, it's way too expensive to have done! The fix is to run your HDMI directly to your TV from source, ie. Cable,DVD, etc. then run coaxial digital or optical to your receiver for audio. The catch.. How many HDMI inputs your TV has will limit sources hooked up via HDMI. If you want further info on HDMI issues, just google "HDMI forums" and there are many different sites to answer the problems of HDMI. Hope this helps.
