If you DS isn't charging there are two possible things that could be causing this.
The first one is that the batter inside the DS is shot, in which case you'd have to replace it.
The other one also requires replacement, and that's assuming your charger itself isn't working. Either way, you're probably going to need to replace something.
One way you could tell which is messed up is to try and charge someone else's DS. If that doesn't work then it's most likely the charger.
i would suggest trying to find what the issue is, if you know anyone who has a different charger, try it on your daughter's ds. if it still doesn't work, it's a DS problem...if it's under warranty, go to whatever store you bought it at and have them fix or replace it. If you try the different charger and it DOES work, then the only problem is the charger...so then all you have to do is go buy a new charger...hope this helps.
Have you tried to turn the console on while the charger is attached?
If yes, then take the battery out, plug the charger in again and try turning it on.
