Samsung DVD-HR720 DVD Recorder Logo
Posted on Dec 03, 2007
Dvd eject button does not respond
Display :reads "load "
buttons : dvd blinks and hdd is lighted
harddisk is running
fan is dead and should be running al the time
no button on the front gives any change
problems started after plugging on the power at the wallsocket
looks like sort of power or fuse problem
Please help me out ?
  • 1 more comment
  • zapzap Jan 05, 2008
    i have the exact same problem, except i was watching a dvd and it sudenly just stopped responding
  • hesselberg Nov 02, 2008
    exact same problem as paul p. (except mine is a DVD-HR725)
  • tommaso7 Nov 22, 2008
    I have the same problem...
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Jan 12, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
980
Points
Had a similar problem after loading a suspect dvd (one I had buned myself) Could not do anything - stuck at loading.
Try this :
  1. Unplug and wait 10 seconds
  2. plug it back in and wait 1 minute. DO NOT PRESS ANY BUTTONS!
  3. With the machine still in the standby state, press eject on the REMOTE. It should eject without trying to read the disk.
Good luck. It worked for me.
2helpful
Acer 4520 Dead, Blank screen , No response...
It sounds like something on the motherboard has possibly shorted out. That can range from the CPU to RAM to the DVD. If it's still under warranty I would suggest sending it in for repair.
If you do send it in, please let them know to backup your harddrive if they have to reformat and restore it for any reason. Your important files are still there and safe.
3helpful
2answers
Eject botton does not respond
there is a tiny drive belt connecting a small motor to the loading tray.when they stretch,they run but do not open the door.if that is the case,putting your ear on the machine while hitting the eject button will enable you to hear the loading motor running inside.if you do not hear anything,it is a different problem
1helpful
3answers
The DVD tray doesnt eject
either it is the ribbon wire, the motor that ejects the tray or the belt that connect the tray and motor is the problem. In case the above three are fine, replace the drive as the sparking might kill your moterboard.
Dvd drive is not responding on 360
the ROM drive has failed. you will have to install a new drive or repair the components within this ROM.
turn off your console, unplug from the power source, remove the harddrive, reattach the harddrive, plug it back in, power on
Dvd stuck in conia clcd1930
To Eject the DVD, my conia clcd1930 needs to be in "DVD" mode. This Mode appears to activate power to the entire DVD module. So the Eject button will only work in this mode.
3answers
DVDR 3350H KEEP READING AND WON'T EJECT DISC
Look under the faceplate where the disc tray ejects and see if there is a small hole. If so, use a straightened paper clip to eject the disc manually by pushing it into the hole about an inch. If that works, then reset the power on the unit and try a nonrecorded type disc to see if the unit works at all.
Other than that, you'll have to take the unit apart to get your disc out.
Hope that helps...
Geno
3helpful
2answers
Dvd hr720
Had a similar problem after loading a suspect dvd (one I had burned myself) Could not do anything - stuck at loading. Don't remember if the fan was running. From what I have read these units are touchy to bad disks (DVD or HDD) If yours has a DVD inserted try this :
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
