I have a Kenmore Series 90 top loading washing machine. When I start a wash cycle most times no water comes in. Immediately it starts the agitation cycle with no water in the tub. If I mess with the reset button for the load size the water will come in but fills to the top of the tub no matter what level is set. The water also does not come in when it gets to the rinse cycle unless I mess with the load size reset know. Is this a timer problem?
Well you eliminated the fill valve when you said it does fill with water. More than likely its a bad connection on the control board. I wouldn't betmy paycheck on it but thats where I'd start. Take the cover off the control board and while machine is on being really careful wiggle each wire until the water starts in the tub and you have found the problem.
Well, I checked the wiring on the control panel but could not find any loose connections. I also checked the pressure tubing from the pressure switch to the bottom of the tub. No holes or cracks in the tubing. Could it be a problem with the pressure switch?
