Cannot get outdoor temp. to show on SkyScan......put in new batteries on outside module, but don't know how to "reset" it, even pressing the reset button doesn't fix the problem.Karen Swaine Phoenix, AZ
If your outside temperature is not showing on your clock, that may mean that the clock and the transmitter have lost their connection. To reconnect them you must first take the batteries out of both of the units for 15 minutes. First put the batteries back into the transmitter, and then the clock. Let them sit side by side inside your home. When both the indoor and outdoor temperatures show on your clock with the same reading, or within two degrees of each other, then you may put your transmitter back outside. Remember to keep the transmitter out of the direct sun in a dry place. Also keep it away from metal, which can affect the readings.
you probably need to 'pair' the outdoor sensor with the main base: look for a 'channel' button, as these units usually can get information from several sensors and differentiate them by a channel number.
Seems to be a consistent problem with Skyscan. I have the 88800 model and my outdoor transmitter isn't transmitting the temperature either. We've replaced the batteries in both the transmitter and clock and nothing for outdoor temp. It's only been used for 9 months.
Simple, the instructions state that when changing the batteries on the outside temp. sensor, you must also change the batteries on the main clock unit. I had same problem when I changed the sensor batteries until I pulled the batteries from the clock and it reset fine. ( Sensor batteries first, then clock batteries. ) The clock will reset to atomic time overnight so don't worry if it doesn't read correctly at first.
This is a very common problem that is most frequently caused by the outdoor transmitter going bad. They are surprisingly delicate and don't like getting wet.
Try changing the batteries in the CLOCK. I had the same problem in a 3M similar clock and it didn't read the transmitter correctly or eventually, at all, when the CLOCK batteries were getting low.
If you have lost the outside temperature on the clock display after replacing the transmitter battery then do the following:
1. Make sure you have good batteries installed in the remote transmitter 2. Remove the batteries from the main clock and keep them out until the clock display disappers. 3. Re-install the batteries in the clock. 4. Wait until the display returns and includes the outside temperature display as well. 5. Set the clock again for current time/date etc. 6. Bingo. You are in business.
After replacing the transmitter batteries several times, I tried replacing the clock batteries. They must have been getting low. Once I put in new batteries in the clock it worked fine. Good Luck.
