Samsung HT-X40 System Logo
Posted on Aug 23, 2009
How can i listen to my tv through my cinema system
We just bought a samsung plasma tv with a samsung home cinema system ht-z320 how do i listen to the tv through the home cinema systems and not just dvd's
  • Anonymous May 11, 2010
    Are you using a cable, sat, or converter box?
Anonymous
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Dec 27, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1789
Points
5
Use a fiber optic cable
  • Anonymous Jul 11, 2013
    Will the jvc home theater system work with this fibre optic cable?
2helpful
2answers
Just bought a Samsung ht-z320. I used the hdmi
How is the cable box audio connected to the Samsung? That is where the sound comes FROM. HDMI carries signal TO the TV.
The single optical digital input is a limitation if you get HDTV through cable. You probably use it for the DVD.
I found this quote from the manufacturer's propoganda, "deliver the greatest impact from all your digital media". Yeah, all ONE hardware source of it.
You could manually attach the optical output (if it exists) of the Cable Box to optical input on the Samsung for multichannel-audio TV viewing (listening). OR, you could run the RCA L&R analog audio outputs out of the Cable Box into one of the Aux Inputs, but no actual surround will be produced.
I have a Samsung 5.1Ch Home Cinema System. HT-Z320 and a SONY Integrated Digital TV DV3. Is there any way that i can set the surround up so that the tv can be played througt surround system and not just...
I just hooked up my HT-Z320 today. I had to use an optical audio cable to connect the audio output from my TV to the optical audio input in the samsung receiver (it's the only optical jack on the receiver). Then with your samsung remote in DVD/Receiver mode, click the Auxiliary button (near the top right of the remote). Hope this helps.
Connecting LG 42PG20 TV to Samsung HT-Z320 receiver
output on TV cable digital reciever to home theater digital reciever in via an optical cable.lower the volume on the TV cable digital reciever to get the most out of the surround sound system.
Samsung HT-A100 Home Cinema system plays cd only with tv on!
You need to put away the remote for your TV and use only the remote for your HT system. Your HT remote should work on your TV by default. Your Samsung HT remote should have a TV button and a DVD/Receiver button (or HT button). When using only the TV, press the TV button and then use it for just the TV and when using the HT system, press the DVD/Receiver button and then you can use the HT system.
If for some reason your TV is not set on the Samsung HT remote by default, your HT users manual should have a list of codes that you can use to program your HT remote. Hope that helps you. Gary
Samsung series 6 tv & Samsung 2:1 home theatre problems
if you got all the lead you should have fibre optics which connects from dvd to tv and then set your dvd to digi in. you should get the sound. i have same cinema system and i have done the same
5helpful
2answers
I cant get my samsung home cinema system to play through my t.v
I bought the optical audio cable ($15 WalMart) and use the Digital In on the DVD player to play the sound through the surround system and turned the TV speakers off. Works great! The optial audio has square ends and looks transparent with just one round shaped cable that goes from the TV to the back of the DVD player.
3answers
SAMSUNG LE40R88BDX 40" LCD TV with DVD home Cinema system
if ur surround hasnt got digital in then it wont work also its better to use the red white and yellow wire, i have hdmi and them wires hooked up and i have sound through everythin all i have to do is put it on aux 2, try it out
HDMI conection
Hi.
Connect the Home cinema and the TV with the HDMI cable. When you turn it on, first turn on the TV and then the home cinema. I hope this works.
Top Samsung Audio Players & Recorders Experts
ZJ Limited
ZJ Limited
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
