Need a configuration (that works) to setup a Cisco 2811 connecting a 2821 router to pass T1 traffic between two PBX's. Both routers are on the same network and have VWIC-2MFT-T1 cards installed. The T1 connection will be used to connect two telephone system PBX's togather.
Example: PBX-1 to Cisco to IP to Cisco to PBX-2.
Are you trying to set up router ?
You can set up your router manually, without the CD.
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
way old post, but no I didn't.
Found another way a month or so.
Thanks anyway.
Did you ever get this problem fixed
Can you provide the text from a "show version" and "show run" command? The required configuration may vary somewhat, depending on the specific software version on the router(s).
