SOURCE: need to know the model
http://paramaxaudio.com/Hometheater.html
By the way this system is part of the white van speaker scam.
SOURCE: i need the code on a paramax audio receiver p-701 for a universal remote.
Hi, you need to refer to you instructions book that came with your RCA remote when you purchased it new. It will have all the codes and instructions on how to program the remote inside the book. But all said and done, even if you find your original manual for your RCA remote and programmed it. It will probably still not work because RCA universal remotes arn't made very well to be compatible to receivers.
I suggest getting your original remote if it is still available. Try going to Replacement Remotes, as they have most all original remotes available and you will not have to program an original remote from them. Search for your model of receiver in their search box.
SOURCE: have sanyo FXWJ remote need codes for paramax home audio system
083,071,059.053,086 are the codes to check. If you wish to get more details, check this site. Pull up previous posts there. Setup code list and setup proceedings to many popular brand remote controls are given. Three digit, four digit, five digits and two-digit code list are there. Check the site with patience. Surely you'll get a solution to your problem. Search the site by 'Timeslide' option. It will make search easy. Or, type in the brand name to your device into its search box, and press "Enter"
If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the site http://electrohelponline.blogspot.com/ Check this site too. http://remotesearch.blogspot.com/ Universal remote controls are available at most of the electronic spare part selling shops.
