I have a gamma 5 radio in vw passat 2000 and alpine chm s-620 changer and I cannot connect the 2 utilities because of the wires difference.Does anybody know the way to do it?Thx.
sounds like the changer was plugged into the antenna jack of the radio. this means that you can run it through any radio simply by sending a signal to a preset station on the radio and listening to it through tuner. the control unit ran the changer itself. you may be able to obtain replacement cables from pacparts.com
The Alpine CHA- and CHM- changers all use the same magazine. You can search eBay or google shopping for "Alpine CHM Magazine" and you should see a variety of sellers, with prices from 25ish for used ones up to 40ish for new ones.
It won't work if the radio doesn't have a cd changer input. The radio/receiver has to have been designed/programmed to interface with the changer since that is what the changer is controlled through.
yes it is possible, but you need to goto a radio shack or electronic store and pick up a 12 volt power supply, then you will have the 12 volts needed so you dont blow it all up putting household current thru it...
