Access through the back panel to have a look at the drain pump which is likely your fault. Run a cycle and watch it when it drains you will likely see water leaking from the pump (about $25 and easy to change)
Thank you Colin, but how do I gain access to the back panel? I do not find any screws to dismount the back panel, the body is wrapped around and welded at the sides. Do i have to open the top bit up and remove the body? Or do i have to remove the bottom panel? Thanks.
Saqib.
