I have Asus WL 520gu connected to my cable modem (Scientific Atlanta). The router can read the modem, but no internet access. I used auto setup, no manual input. Can anyone help me? Any suggestion is appreciated.
1, connect your wireless router with cable to your laptop,
2. Login into your Asus-WL520gu and setup your wireless how you want it to run." do not bother with putting your username settings in there"
3. In your Asus-WL-520gu after setting up your wireless turn the DHCP off in it.
4. Now connect the cable that you have connected to your laptop to your router instead of your laptop.
""You should now be able to connect to the wireless with your settings. and connect anything ells you want to the other 4 ports on the back of you wireless router"" note: do not connect anything to the WAN port as it is used for DSL modems; and not Routers with ADSL modem.
when connecting a router to a router - the one that is connecting you to the internet needs DHCP turned on because it is the one that will be giving you IPs and Gateway settings - the other router such as wireless router after setting it up needs its DHCP turned off - other wise you will have 2 routers trying to do the same thing with ip's and gateways. And you should never connect a modem router to the WAN port as it is a modem router and NOT just a DSL-modem. The WAN port is intended for DSL-modems only. Not only consumers but also many technicians make that mistake
Is the AT&T 2Wire 2701HGB a "modem router" or a "DSL-Modem"?
