HF 8 Space heater with a bad switch
I have a Patton Electric Space heater model number HF8 with a bad control switch. Is it more cost effective to repair/replace the switch or replace the heater?
Thanks-
Randy
    President:
  • 3,433 Answers
If you locate and procure a switch, you can more than likely replace it yourself. Get a switch of like and you can see what you have to deal with, Always disconnect the electricity before you work on it Good Luck. It really isn't a big deal to do.If you can take and send pics by e-mail I can walk you through. Co7196@yahoo.com
Posted on Aug 23, 2009
SOURCE:
Can I buy a heating element for this heater?
On google
Patton replace heating element Heaters Questions ... - Fixya
www.fixya.com > Forum > Tags > replace heating element > Heaters
Patton heaters replace heating element related questions and answers. Ask yourPatton ... I can't seem to find a phone number for the manufacturer to call for parts. Any help? ... Question about PQH307UM Electric Utility Heater. 1 Answer ...
Patton PQH307UM Electric Utility Heater Quartz elements ...
www.fixya.com > ... > Patton > Patton PQH307UM Electric Utility Heater
Patton PQH307UM Electric Utility Heater, quartz elements replacement related ...Element. Where can I find replacement quartz tube heating. Element Infrared ...
Patton PQH307UM Electric Utility Heater Element ... - Fixya
Patton PQH307UM Electric Utility Heater, element related issues. Get free help, solutions & advice from top Patton experts. ... The heating element is above the thermostat, and all you will see is a round disc with two wires attaching to. Ad.
Patton PUH680-U Utility Heater Replacement fan motor ...
Jan 19, 2016 | Patton PQH307UM Electric Utility Heater
Patton space heater power knob isn't working
First thing check see if you have power going to switch with a multimeter if you have one if there's power going in it switch need new switch probly you can us your multimeter to test switch on ohms
Mar 01, 2013 | Heating & Cooling
Will the patton electric heater significantly raise my electric bill
1500 watts is 1.5 kilowatts. Run it for 1 hour and you have 1.5 kilowatt hours. My electricity costs .08 per kilowatt hour so, when I run my 1500 watt space heater, it costs me a whopping .12 per hour to operate. I can afford 12 cents per hour, compared to oil at $3.50 per gallon and a burner that burns up to 3 gallons per hour.
Dec 23, 2012 | Patton Electric Patton PUH680-U Electric...
Is there a recall on patton heater mod puh9000.mine shorts out? thank you
Yes, there is/was a recall on some Patton Heaters, but I don't recall if your model # is one of them. For more info search Google for Patton Heater Recall Notice and you'll find the correct site.
Jan 26, 2011 | Patton Electric Heating & Cooling
Patton MH761 coil wire can these be replaced? The wire only heat about an 1/8 of the total length and does not produce much heat. I asked about it at the local hardware store and they indicated that the...
Nickel Chrome hard wire in coils for heater element are not worth stocking as new complete heaters are very inexpensive and as a qualified electrician must fit it, to replace the heater element is not cost effective.
Jul 15, 2017 | Patton MH761 Utility Heater
My Patton PUH680 space heater is not working. Do you offer replacement coils?
Check out this tip that I wrote about space heater problems..
DeLonghi Space Heater does not Heat
heatman101
Dec 06, 2010 | Patton PUH680-U Utility Heater
I have a patton puh682 1500 watt heater and after a while it just seems to turn off is there some kind of timer or heat control?
Under the main black knob is a bi-metal switch which shuts down the heat at various temps depending on your setting. Their is no timer.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 21, 2010 | Patton Electric Patton PUH680-U Electric...
Looking for a phone number to contact PATTON SPACE HEATER COMPANY
Patton at l-800-528-6600 ext. 1722 (Arizona: l-800-352-0458 ext. 1722; Alaska l-800-528-0470 ext. 1722)
Apr 01, 2009 | Patton Electric Patton PUH680-U Electric...
Patton space Heater Model # prh-5
check that the rocker switch inside isn't stuck, when the rocker swings it shuts the unit off. if it is full of dust it may be stuck. may just be bad.
Nov 12, 2007 | Patton PUH680-U Utility Heater
Heating & Cooling Logo
147 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Donni Steen
Marvin
Marvin
