I bought an used Dell inspiron 1545, but it is locked with "password authentication system" try calling dell, but they wont help since I don't know the name of previous owner. Is there any way to reset or to go around this password? please help.
Go to www.novatecdirect.com they can help, works for me everytime.
I had the same problem and after hours of research I found the solution here.
this site: www.biosunlock.com
If there are several programs that allow, reset the password, some would say it is and others simply deleted, the latter being the most effective, some have to be paid and some are free, the Ophcrack is one of the best free, and the PC Helper is a good option if you are not interested in restoring the old password, simply search Google for Password reset or Password recovery and find an unlimited list, I hope having served
#8ns18h1-595b can u help me to get bios password for this..
email me at [email protected]
I'm another victim of Dell's password authentication system:
My system is: Inspiron 1545
Service tag: JQ1N9H1
Express Service Code: 42933749941
Valet key (gray plastic end) which can start the vehicle and unlock/lock all doors, but can not unlock/lock the storage compartments, or rear compartment lid lock.
Important: The transponder values are not readable and can not be serviced separately.
Theft Deterrent Module
The theft deterrent module contains the software for controlling the VTD System. The theft deterrent module uses the following inputs and outputs to control the VTD system.
Inputs
Battery voltage from the underhood fuse block PCM/BATT fuse, circuit 240 (ORN).
Ignition start voltage from the ignition switch, circuit 1390 (WHT).
Ground, circuit 450 (BLK).
Outputs
Password exchange with the PCM (fuel enable), class 2 message circuit 1807 (PPL).
Powertrain Control Module (PCM)
The PCM verifies that the passwords received from the theft deterrent module via the class 2 serial data line are valid. If a password is invalid the PCM disables the fuel delivery system. If the password is valid the PCM enables the fuel delivery system.
Starter Relay
The starter relay is controlled by the PCM module via class 2 serial data (CKT 1807 PPL). If the theft deterrent module measures the correct transponder value, the PCM module switches the starter enable control (CKT 447 YEL) to ground. The relay is energized if the ignition switch is in the START position and the gear selector is in the PARK or NEUTRAL positions.
There is a way butyou should have some proof of legal ownership or you won't get any legit help.
