Stops through the cycle with error 4E...where is the pip located that has a sensor??
When error message 4E is displayed, you should clean the water hose mesh filter. To do this:
1. Turn off the water source to the washing machine.
2. Unscrew the hose from the back of the washing machine.
3. With a pair of pliers, gently pull out the mesh filter from the end of the hose and rinse it under water until clean. Also clean the inside and outside of the threaded connector.
4. Push the filter back into place.
5. Screw the hose back onto the washing machine.
6. Turn on the faucet and make sure the connections are watertight.
Also, please check the following:
• Make sure the source water faucet is turned on.
• Check the water pressure.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!!
Samsung WF203ANW Front Load Washer This video will help you diagnose the fault on 3e error codes and the video will help you solve the problem
Wh is 4e it start and stop
