SOURCE: error 357 waste toner full
If you dumped out the full waste toner bottle The gear that drives the gear on the waste toner bottle has broken off.
SOURCE: error c7990 waste toner full
Open the left door.remove the waste toner bottle.It is whitish, odd shaped and directly in the front.throw it in the trash carefully.replace it with a new one.close the door.Good luck!
SOURCE: My Oki C9600 Printer showed an error message,
940: Error
Waste Toner Transfer Error
The transfer mechanism of the
toner duct for ID is not operating
properly.
Check to confirm that the basket
assembly is in position (if it is
engaged with the gear of the
printer).
Check to confirm that the holder
magnet D contains a magnet,
and check the magnetic polarity.
Replace the HAL IC circuit
board.
Replace the duct assembly
toner.
SOURCE: E000019-0000 error message display in
Switch OFF your machine and remove waste toner and clean up the bottle(locate at your left side)
SOURCE: I get error message "waste
Open the right side door. there at the bottom is a long plastic bottle full of waste toner. If you have no spare bottle then carefully (dont create dust) empty toner into a bin liner. Now tap the bottle on the table to allow any toner on the sides to fall back to the bottom. now refit and all should be well.
