All of a sudden, I cannot copy files FROM my Western Digital 500GB external drive to my iMac. I CAN copy files TO the external drive from my iMac. My cursor turns into that circle-with-the-line-through-it. When the ext drive is connected to PC, it seems to work fine.
Check the file system of your hard drive. If your PC is recognizing it, check if its a FAT or NTFS. If it is NTFS then you have to reformat it using your Mac and choose FAT. Mac OS recognizes NTFS as a read only drive. If you plan using it with your PC and MAC you should format it using your mac and choose MS-DOS in disc Utility. You cannot format the drive using your PC Computer with a FAT file system because of the capacity. Only Mac can format it with a FAT file system.
Hi there! Quick question for you before I make any assumptions or suggestions: Was the drive configured and formatted using your iMac or the PC?
