I have a PAC 03 U model that functioned well until this summer. Now it's leaking buckets. Sometimes the water goes into the reservoir but most of the time it spills all over the hardwood floor. The filters have been cleaned and there doesn't appear to be any obstructions in the intakes. I'm getting weary 'babysitting' the airconditioner! Any solutions??? HELP.
If you have cleaned the air filters then that is the first step. Next you want to check the condenser coil. That is the coil that is outside. If it is dirty you will have a low charge situation which could cause lots of condensation. Also if the condenser coil on the outside is clean and you are getting lots of water than you my have low charge of refridgerant. If that is the case you will need a professional to come and charge the unit and find the leak. Did you check to see that the unit is level. Because is should drain to the outside. The unit should be installed in a way that the water drains to the outside.
