Check one area at a time try the broiler first see if the glow plug or ignighter is glowing red hot the glow plugs have to get so hot before the gas valve will open, it is not usual for both to go at the same time, as for fuses or resets i have never seen these on any stoves, if you find that one works and the other does the glow plug is bad if not the gas valve may have went bad
