SOURCE: Sears lawn tractor. While mowing, ran over a
the branch probably got cought in the belt that runs the rearend it may have caused it to come off check the drive belt
SOURCE: looking for wiring diagram for sears tractor
Go to www.searspartsdirect.com Enter your model number in the appropriate box, when the page loads, look on the left side of the page where it says "Browse sub-components" and click on "tractor-schematic" this will open to a total wiring diagram for you
SOURCE: Sears Craftman Garage door opener model # 41A3493-1
That isn't the model number you give it is the part number for the logic board. The model number is on the opposite end of the motor unit and starts with 139. If you are asking if the opener should reverse when it hits an obstacle the answer is yes. If it doesn't it is not adjusted correctly or is faulty.
SOURCE: Need owners manual for 2.2cu in sears craftman chainsaw
Download the PDF version from http://www.hammerwall.com/Manuals/Craftsman/Description/358.352161/Craftsman%2016%20Inch%20Bar%20Gas%20Chain%20Saw/L0708268/
