The battery on my D80 is fully charged. When I power up though, the camera shows low on power and does not function. When I power on and off, it functions briefly, then reverts to low on power and stops functioning.
this error message is usually caused by a low battery. Here are some steps you can try to fix the issue:
Remove the battery from your camera.
Fully charge the battery using the Nikon D80 battery charger.
Remove the memory card and reset the camera by using the reset option in the menu or by pressing the reset switch on the camera's body, under the connector cover .
If the error persists, Nikon recommends waiting for one or two days before sending the camera in for inspection
Hi
Have you tried resetting the camera back to factory settings? This should clear up any problems...if it doesn't it may at least let you know what the problem is? Also...do not use an SD card no bigger than 2 gigs, What is thee display showing? Make sure the date and time are correct! Get back to me if you need any more help...Thanks...John,
Make sure you are using a fully charged Nikon battery. Problems may sometimes happen with generic batteries. If you are using a Nikon batt, then seems you may need to bring this in for servicing
NOTE: Please rate our help to keep this free service online
You can check the status of your battery, including chargeble life remaining, in the Setup Menu. You need to have the CSM/Setup menu option to display Full menus, not Simple, in order to get battery status. So see if that battery status selection says you need to replace the battery.
Since you can shake the camera to get full battery, it's possible the battery contacts (on the battery or in the camera) are dirty, so check that.
If you do need a new battery, spend the few extra bucks to get a genuine Nikon EN-EL3e from a Nikon dealer. I have learned that many off-brand batteries do not properly implement a needed reserve, and "Genuine Nikon" batteries bought online from non-dealers are often counterfeit, just relabeled junk.
mikeandlenna,
I'm guessing you have had the D80 over a year and past the warranty so you purchased a new battery. If the battery is fully charged and reads partial, check to make sure the contacts are clean (the compartment in the camera might have something on it or hopefully not some corrosion) use a dry q-tip to test and see if anything comes off the contact and on to the q-tip, if that's what it is, then you will be back in business. let me know if that's not it and we can try another route.
randy320sgi
