A E100 code is a Laser error code. I would look to see if all the doors are closed and look on the doors & look to see if a small tab has broken OFF. That is most likely the pin or tab that opens the laser cover... Or you may have a bad laser unit. They do have bears that fail from time time.. Good Luck
Hi,the most common cause for E100 is the drum unit. At the rear of the drum unit should be a small peg pointing into the machine. This gets broken off. It's purpose is to operate a laser cut off shield when the drum is removed so to prevent laser exposure. If peg is missing laser will not be detected by the system and give E100. Can be repaired or will require a new drum if it has done more than 40 to 60K copies.
"BD interval error"..
just enter service mode & reset ( CLEAR ALL ) Additional Function>>>28>>>>Additional Functions Scroll through to find CLEAR Select all...
Your printer show Error code E000 suggests the problem history has recognized all of these of the following error codes four moments: Error code E001;Code E002;Error E003. Printer Canon E000 error will be removed in the service mode.
Please try reset factory your canon printer..but if it still show error code E000 again ,you can try with a genuine fuser unit (reseting fuser unit). Good luck
Solution 3: Try this, atempt will clear canon E000 code in Service mode:
1.Press ADDITIONAL FUNCTIONS, #
2.Go to #7 Printer and Press OK
3.Go to #4 Printer Reset and Press OK
4.Yes = ( * )
