Sounds like possibly it could be connection related between any AV/Cable ports. Worst case would be the capacitors of the motherboard leaking. It's possible to fix anything. Just make sure you have the knowledge and the right equipment.
bad convergence would cause show to look as if it was supposed to be a 3-d movie, if a bulb was going out then people would look purple blue -green,or some other off color, so likely the green bulb is going out from the color of the people you described.
We have a 60" panasonic rear projection television and the color fades in and out. What do you think is the problem the tv is only two years old and is now starting to apear in black and white sometimes. What can be the problem?
have JVC AV-32F702 TV. It's picture color is very red. unable to adjust colors through menu. Channel numbers are also in red now instead of normal green. any suggestion?
please check red color cathode circuit
1 check red output from ic to red cathode ckt
2 check voltage on r output ckt& ic or tr.
3 check loose contact in red cathode ckt
4 check crt base for loose.
5 loose connector
6 chroma ic
thanks
It seems your set has a loose conection in the high voltage circuits,in fact by now it should have many loose conections in different areas like the power supply and the horizontal deflection circuits,if you are familiar with tv service you can use the information as the first step to take,some of the loose conections are hard to see even for the trained technician but the one giving you this problem should not be hard to see,if you are not too familiar with tv service be safe and call for assistance from a servicer a least for an estimate.
