When you switch the printer on it does not warm-up, no sound, no gear or fan turn only green led light on and blue screen with message - eeprom error. what could be the cause?
SOURCE: Xerox Phaser 6100- Error message - "Fuser Error Low Temprature"
Try this before replacing the fuser.
You do have to reset a new fuser also.
Reset Fuser Life
SOURCE: Xerox phaser 6180n
Sounds like the memory stick is loose.
If you just received it, that machine has a one year warranty on it.
Call and Xerox will send someone out, or else they will replace it.
Your going to love that printer. WOW what print quality it has.
But your problem most likely was due to shipping and something coming lose.
Call 1-800-835-6100, follow the prompts, they will help make it right.
SOURCE: XEROX 8550 DP ERROR Message 09,035,43; 10192
That is a cyan, ( blue) ink stick fault. What is happening is that the cyan ink sticks are not advancing down the ink loader properly.
Open the area where you load the ink and you probably have a cracked, twisted or otherwise stuck ink stick, the code you are reporting specifically refers to the cyan sticks. If you have to remove them, take a screw, a drywall screw is best, and twist it into the sticks and slide it back and out, then replace them or add new ones. But thats your problem.
SOURCE: Laser Error Error message 061-370 for Xerox Phaser 6125
From the service manual:
Troubleshooting Procedure Table
Step Actions and Questions Yes No
1 Check the Laser Unit for correct
installation.
Is the Laser Unit correctly installed?
Go to step 3. Reinstall the
Laser Unit. Go
to step 2.
2 Cycle the power.
Does the error still occur?
Go to step 3. Complete.
3 Check the wiring harness connectors
P/J40, P/J41, P/J411, and P/J412
between the MCU Board and the Laser
Unit.
Are the connectors securely
connected?
Go to step 5 Reconnect the
connectors. Go
to step 4.
4 Cycle the power.
Go to step 5. Complete.
5 Replace the Laser Unit (page 8-31).
Replace the
MCU Board
(page 8-59).
Complete.
SOURCE: i own a Xerox Phaser 3100MFP and it keeps giving
please your xerox phaser is in fuser light is checked is not courently okthis parts is damaze? then changing the fuser temp and new added.
