My Kenmore Coldspot model 106 top freezer refrigerator is not cold. Three times before, I have unplugged it, let the whole thing defrost, cleaned it out & plugged it back in, & it will work fine for awhile, then after a few weeks the fridge doesn't keep anything cold. It runs, but it's not cooling. Once the freezer and the fridge both stopped cooling/freezing, otherwise it's just the refrigerator. The first time it happened the back of the freezer was a block of ice (took the cover off & made sure it was all melted before turning it back on), but it has not been like that since. Is it worth trying to fix it? Any advice is much appreciated!
Either the freezer continues to freeze up (most likely due to low refrigerant, due to a leak), or there is an obstruction between the freezer and the refrigerator (refrigerators get their cooling from the freezer).
Given that it works after you defrost it, I'm going with low gas. Call a professional to see if the leak can be fixed. If the unit is more than 10 years old, just get a new one.
Kenmore coldspot model 106 9552911
The freeze section is working but fridge section is not cold.
There is two vent in fridge section and only top vent flow cold air in
not bottom vent.(no cold air) Can you tell me the solution?
I unplug the refrigerator for 30 hours but same problem.
Check
out these tips...they can help you figure out what is going wrong
with your refrigerator and why it is not cooling
Refrigerator
not Cooling
or Fridge not Cooling
How to Defrost Refrigerator Defrost
Timer Problem
Water
Running in refrigerator
from Freezer
Refrigerator
or Freezer not Cooling or Getting Cold
heatman101
Check
Refrigerator
not Cooling
Timer Problem
Water
from Freezer
Refrigerator
heatman101
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
