How do I restore the small icons on my task bar for things like Safely Remove Hardware and network connection status? I've tried doing it through Properties when I right click on the task bar but even though I tell it to always show these items nothing happens.
Windows usually hides the task bar icons you have not used recently. If that is the case, you must have a small left arrow < at the left of the last icon displayed. Click that arrow and the hidden icons will be displayed for a short while.
Usually the safely remove hardware is present (shown or hidden) whenever there is a removable equipement.
For the local or dial up connection, you can configure your computer to display it on the task bar. Here is how to do it in Windows XP
1. Press the Start button on the left, choose Connect To > Show all connections. You will see all your connections, each one symbolized by an icon. 2. Point the mouse cursor to the one you want, Right Click Mouse button, then Properties. 3 Under the General Tab, put a check mark in Show icon in notification area when connected 4. Click OK.
The system tray in Windows XP is the right side of the small blue bar at the bottom of the screen that houses the clock and a few other small icons. You can add icons to the system tray for ease of access, including the "Safely Remove Hardware" icon, which allows you to easily remove hardware from your computer.
Turn on the Windows XP computer and right-click the taskbar. Select "Properties" from the menu that appears. Check "Hide Inactive Icons", then select "Customize" A new window appears with all of the icons currently on the system tray, along with icons also for some programs that don't appear on the tray. Click next to the icon "Safely Remove Hardware," then check the box "Always Show". Click "Apply". Safely Remove Hardware Icon? http://www.pulpfusion1.com/demotech/e_article000253202.cfm
click start right click on your usb scandisk select remove scan disk safely or in the bottom task bar there should be a green tick or a small white triangle click on them you will see to remove hardware safely tab
If you have not already installed the Device Manager, download the .exe file to install the latest version of the Device Manager application from http://www.philips.com/support. Enter your language preference and the model number e.g.hdd070. Select Software under Product Support on the left of the screen. Scroll down and click on the .exe file of your preferred language under the category PC software. The program will install both Musicmatch® Jukebox and Device Manager in one go automatically.
Connect the hdd to the power supply with the AC/DC adapter.
Launch the Device Manager at Start->Programs->Philips GoGear HDD->Philips GoGear HDD on your PC IMPORTANT: All music & content of your micro jukebox will be erased once the factory setting is restored.
A dialogue box will pop up; click Restore and OK to confirm and start restoring the unit to its factory setting.
Follow all screen instructions to complete the restoration.
The Device Manager will close automatically once the success message is displayed. Safely remove your GoGear micro jukebox by clicking on the EJECT HARDWARE icon in your task tray bar. When prompted, "The USB Mass Storage Device can now be safely removed from the system", click OK and unplug your micro jukebox.
I guess you're trying to eject the Kindle from the task bar "(safely remove hardware". Try going into Start/Computer/right click on Kindle/ select eject. This worked for me when I had the same problem.
When you connect your Kindle to a PC, it automatically goes to USB mode, allowing access to its internal memory from the PC. The Kindle cannot display a book for reading at the same time. It would require quite complicated handling, for example, to display a book while the book is deleted by the PC concurrently. Allowing only one machine access to the internal memory at a time avoids any concurrency issues.
If you want to read books while continue charging, on the PC:
Windows XP, Windows Vista: find the "Safely Remove Hardware" button in the status bar (right side of the task bar), and select "Eject" for the Kindle device.
Windows 7: Open "My Computer", press the right mouse button on the drive icon representing your Kindle's internal memory and select "Eject".
On the left side of the player below the hold button is a hole labeled reset. insert an unbent paper clip until the unit shuts down (Blank Screen). Then press the play/pause key until unit lights up.
If this fails, the firmware of your GoGear may be corrupted.
Make sure that your computer is online and connecting to the Internet. Launch the Firmware Manager at Start->Programs->Philips Firmware Manager on your PC
Connect your GoGear to the computer while pressing & holding the key until the Firmware Manager recognize the GoGear and a dialogue box pop up in recover mode.
Click Start to confirm and start recovering the unit to its factory setting IMPORTANT: All music & content of your GoGear Player will be erased once the factory setting is restored.
Follow all screen instructions and click Finish at the end to complete the recovery.
The Firmware manager will close automatically once the success message is displayed. Close all opened application and then safely remove your GoGear by clicking on the EJECT HARDWARE icon in your task tray bar. When prompted, "The USB Mass Storage Device can now be safely removed from the system", click OK and unplug your micro jukebox.
Click on Start,click on control panel, click on Network and Internet and Connections, Click on Network Connections, The two small computer icon should be displayed. Right click on this icon,select properties. At bottom of this window check box to display icon on task bar, click on OK. close all windows.
"removing my usb stick" - This seems like a statement, not a question.
That said, the biggest problem people have removing the USB stick from a computer is that they fail to unmount the drive before removing it. In Windows this can be done by left clicking the "Safely Remove Hardware" icon in the task bar, clicking your device, and then waiting for it to tell you that it is ready. With Mac and Linux you just right-click and unmount the drive.
Either way, not doing this can wipe your USB drive or corrupt your files.
Go to Start/Settings/Network Connections. When the window opens right
click on the Wireless Network Icon and select Properties. In XP there
should be a check box to allow display of notification when connected.
If some other OS, hold the right button down on the Icon and drag it to
the task bar. It should drop an icon for showing the status.
Before doing all of this, is there an arrow to the left of the icons? If so, click on it see if the Icon is simply hidden.
When the "safely remove hardware" icon is in the status bar (the by time) disconnet the mp3 player. After a few seconds connect it again. Then reboot the computer system. You will then be able to see the contents of the mp3 payer.
I tried and it works. Also it means the player could be removed without clicking on"safely remove hardware".
