Philips SA3025/37 Flash MP3 Player Logo
Posted on Aug 22, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to download video songs for philips audio player of 1 GB?
I am having the philips audio player with 1 GB capacity and i want to download video songs on my player. How should i do and how can i convert that video songs that my player can understand.. please tell me the procedure in detail..
Neciforo Llanto
Level 2:
President:
  • Expert 942 Answers
  • Posted on Aug 22, 2009
Neciforo Llanto
Expert
Level 2:
President:
Answers
942
Questions
0
Helped
315737
Points
109
Hi..
First, you can download video from youtube witch is any video you want. To download a video you need a youtube down loader.
Second, The video witch is downloaded from youtube is FLV format you need to convert it. To convert you need a video converter, "if you do not have idea about converter, try to use this" (moyea converter). You can convert FLV video to any format witch your player can play video.
If you have already converted the video. You can copy and paste it to your player.
Be sure that you will know what is the video format of your player.
Good luck! Thanks for using fixya.
Regards
PCmania
Memory capacity
Yes it should. I would remove all of the contents on card and save them then reformat the card and check to see if the full space is available. If not there is freeware available to restore these things to correct amount. If it cannot be done then the card has an issue and needs to be replaced.
I dont know how to put songs in my song nwe005
How do I Put Music on an NW-E003F Sony MP3 Player?
The Sony Walkman E003F is a small portable device resembling a flash drive. This Walkman has 1 GB of storage which accommodates about 685 songs. When the battery is at capacity, the Walkman can play back up to 28 hours of audio. The small player has a built-in USB connector to make downloading convenient. If you want to add songs to your MP3 player, you must use Windows Explorer to download MP3-, AAC- and WMA-formatted audio to the device.
Instructions
Remove the USB cap on the player to reveal the USB plug.
Insert the USB plug on the player into the computer's USB port.
Select "My Computer" from the desktop "Start" menu.
Double-click on the "WALKMAN" drive folder to open it.
Double-click to open the "MUSIC" folder.
Drag the audio file from the save location on the computer and drop it in the "MUSIC" folder. The songs will load and play in the order that they are dropped into the folder.
Hope it helped.
How to add video songs directly from youtube.. I downloaded the songs from youtube.. but i cant add that songs to my Philips music player..
Very simple. - Download file from Youtube. i.e MP4 or FLV- Convert with Youtube video to MP3 if you need audio. - Else if you need video convert to Philips supported file format...
FYI Check below link for softwarehttp://lifehacker.com/316478/top-10-free-video-rippers-encoders-and-converters
2helpful
How many songs does my MP3 player hold?
well, for 1 GB, it usually holds maximum of 240 songs. So, u have to multiply it by 16 since its a 16 GB player..However, it will depend on the one capacity coz some have large files (e.g. videos). ok? Cheers!!!
1helpful
Philips GoGear SA3245 (4 GB) Digital Media Player Can I download songs form I Tunes to this device?
You can download music for the GoGear from any reputable website, iTunes. it is just a case of plugging in the USB cable, go to My Computer and Look for the Philips Removable Drive.
open it up, go to the Music Folder and add your MP3 songs.
To add videos to this player you need to use the software Philips provided. It's a bit complicated to use so follow the instructions carefully. The software will convert the videos to a Philips format to enable you to add them to the Video Folder. You can't just add a file as this will not work, it needs to be converted.
Hope this helps you.
1helpful
2answers
How to record music from the computer with a SA2325 MP3 Player. Send me the steps to follow. Thanks
Overview of online support for SA2325/02 ( GB ):
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=SA2325/02&slg=en&scy=GB
Link to the user manual:
http://www.p4c.philips.com/files/s/sa2325_02/sa2325_02_dfu_eng.pdf
Music files MP3 or WMA
Music transfer can be made seeing the player as a USB mass storage device in Windows Explorer, exploring the drives on "my computer": the player should show up as a drive letter with about 2 GB of memory.
The files must have the format and extension as shown on page 17 of the manual:
• Compression format: MP3 / mp3 (8-320 kbps
and VBR; Sample rate: 8, 11.025, 16,
22.050, 24, 32, 44.1, 48kHz),
WMA / wma (64-320kbps)
• ID3-tag support: Song title and artist name
Transferring songs from the computer to the player
After exploring the appropriate music files on the computer, the songs can be dragged and dropped to the memory of the player: read the blue
tips on page 11 of the manual.
Always disconnect the player safely after transfers, see point 3.4.1 of the manual on page 11.
Audio CD converting to mp3 / wma format: RIPPING
When wanting to convert audio CD's to files that can be played on the player, you could use Windows Media Player 11 or MusicMatch Jukebox using the RIP utility.
  • For WMP 11: update your Windows operating system.
  • When using XP MusicMatch Jukebox 10 can be downloaded from next site:
http://www.soft32.com/Download/Free/MusicMatch_Jukebox/4-277-1.html
Right click on the download file under Soft32 Mirrors and select "Save target as..." Rember the download location for executing the file later, having the MusicMatch Jukebox installed.
Need more help ? Just post a comment.
2answers
Can't download songs and videos on the mp3 player.
The songs have to be in the right format. Philips does not recognize iTunes. Some Philips players recognize DRM-encrypted WMA's and some do not. If you download songs from a service that offers Mp3 format only, you will never have a problem. Use Windows Media Player to transfer the songs once they are downloaded from the music service.
-Tha Mp3 Doctor
2answers
My Mp3 Player Only Has 64 Songs Downloaded
check the capacity...it depends on the size of the songs you downloaded...you can check the capacity of your mp3 player by pressing right click and check the properties of your mp3 player
Download music
The Media Converter only works for video files. Music files must be transferred using Windows Media Player. The Philips Device Manager is only good for Repairs and firmware Updates.
-Tha Mp3 Doctor
Top Philips Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
ZJ Limited
ZJ Limited
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
