This is common there is a small pin hole front left corner bend a paper clip straight and insert in the hole the door will open about 1 inch long to go in
it means the drive is bad, tray jamming on eject or old sticker lapels stuck inside ?
or windows is infected or the driver for the DVD drive is wrong one.
This occurs often will CDrom/DVD's. There are two other ways of getting it open. One is to go to my computer, right click on the dvd drive and select eject. The other method is to look for a tiny hole, usually just below the door. Take a paperclip, bend it out and insert this carefully into the hole. This should open the door enough that you can pull out the drive caddy.Sometimes this will be enough to get the drive actiing normally, other times a rubber belt inside the drive has stretched enough times that it no longer opens the door reliably. You usually can continue to use the drive, but eventually you'll find that having to manually eject is too frustrating and replace the drive.
When you say "not eject", I'm assuming you have tried ejecting from a physical button on the drive as well as selecting eject in Windows Explorer. If not, give it a try. If still a problem, note a small hole in the drive. Open a paper clip and gently place one end in the drive. The drive should open. Hope that helps.
Normally no drivers are needed for CD drives other than the ones built into Windows. It might be a dirty lens that is causing the trouble. When the tray opens on a laptop CD drive the lens is exposed and can get touched or exposed to dirt. Try gently cleaning it with a cotton swab to brush off the lens. If the problem continues, the laser may have worn out and is too weak to read now. You can find replacement drives online, or use a USB plug-in external drive.
You will find a small hole on the face of the drive. This is the manual eject mechanism. Insert any wire-like object (a properly sized size paper clip works real well) and push until the disk ejects.
Note: Many times the mechanism is recessed quite far behind the face plate, so make sure the object you use is long enough (again, paper clip).
"Today's the best day of my life...and NOW you're part of it!"
did you try to do the emergency eject ?
jewellers driver in drive pinhole.
use the eject method again, Computer powered Off. Open the drawer and push it back in firmly.
This is an eject button, make/break switch problem.
Also try ejecting the drive from my computer/Right click with mouse ( CD Drive ) Eject.
And ensure the 4 Pin Molex ( Red-Black-Black-Yellow ) is the right way round. Yellow usually faces to the outside of the casing.
HI,
Double check the Ribbon Cable Connector is installed Correctly ( 40-80 Strand IDE ) sometimes if these are not fitted squarely Or pushed in hard enough. Can cause a Problem.
Also try the emergency eject procedure on The Drive. Small jewellers screwdriver Or Needle, insert into the drives faceplate ( pinhole in drives faceplate drawer ) push to open dvd drawer. pull out drawer Gently. And push back in. This ocassionally works for a stcking Drawer/eject mechanism.
Finally try the drive without a disk in ( open/eject Or Close )
